Thread: NEED Pump Suggestion - 33k Gallon Pool - Current Pump Pentair WFE-3 - 3/4 HP
    SirBrowning's Avatar
    Jun 2013
    Northwest Florida
    19
    My Pentair WFE-3 Whisperflo High Performance 3/4 HP pump is failing and it needs to be replaced.
    I have a 20x40 33,000 gallon chlorine pool, no other features, spas, fountains, etc, just the pool.
    I have a booster pump for the Polaris 380.
    Filter type is a sand filter.
    I have a tablet chlorinator.
    What pump do you suggest as a replacement that would be best in regards to energy standpoint, reliability, and longevity?
    Thanks!
    mas985's Avatar
    Pleasanton, CA
    11,983
    Re: NEED Pump Suggestion - 33k Gallon Pool - Current Pump Pentair WFE-3 - 3/4 HP
    How old is the pump? Why not just replace the current motor with a new one? Can upgrade to a two speed at the same time and save a bit on energy costs.
    Mark
    Jun 2013
    Northwest Florida
    19
    Quote Originally Posted by mas985 View Post
    I tried but the housing is so corroded that it isn't a possibility, it literally is falling apart just by touching it so there is nothing for the new motor to bolt onto.
    So which 2 speed motor do you suggest? And does it require any special setup? right now I have the motor hooked up to a timer, do I have to replace that timer or use a special timer if I get a 2 speed?
    Thanks again!
    mas985's Avatar
    Pleasanton, CA
    11,983
    Nearly any low HP 2 speed will do but here are a couple of favorites:
    Pentair SuperFlo 1 HP 340042
    Hayward MaxFlo XL SP2307X102
    IF you want a timer to control the speed, then you would need a two speed timer. If you are ok with a manual switch in the back of the motor, you can special order that.
    Also, both models come in a VS version if interested. It costs more up front but if your power company gives rebates, it can be worth it.
    Mark
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    +1 To what mas said
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
