Thread: CYA test question with K-2006
    Mar 2017
    Sanford/Florida
    2
    Angry CYA test question with K-2006
    Hi, very new pool owner. I tested my CYA with the K-2006. The tests were consistent with a CYA between 60 & 70. When I read pool school it said the results are +- 15PPM so I am wondering what would i base my CYA readings on? The 60 or the 70 or is it 60-15=45 or is it 70+15=85?Confused???
    16000 Gallon with attached 6 foot raised spa, IG, pebble, Pentair Clean & Clear RP with 150 Cartridge, Pentair Intelliflo VS+SVRS 3 HP & Pentair Superflow for water features, Ultra Temp 125K BTU heater/Cooler, Pentair Intellitouch pool automation with I-Phone support, Built 2016, Taylor K-2006 Test Kit, Pentair IC40 SWG, City water with very high CH 450+, No water restrictions.
    May 2011
    lebanon tn
    370
    Re: CYA test question with K-2006
    I would call it 70 and keep everything balanced based on that
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Mar 2017
    Sanford/Florida
    2
    Thank you
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,267
    CYA testing takes a little practice. You can always test your testing method by using R-7065 CYA standard of 50 ppm. It is basically pool water that has a CYA of 50 ppm. It allows you to practice your testing technique.
