Thread: Any downside of removing solar water panels and replace with PVC pipes?
    Jun 2016
    San Jose
    30
    I expect heating efficiency would drop, but still like to double check if there's any other adverse effect, as the water would flow much faster under the same pump pressure.
    I have 9 Fafco water collector panels and 2 of them have major leaks and beyond reparable. I'm sourcing Fafco panels locally. Assuming if cannot find or they are very expensive to replace, can I just remove them?
    It seems to me that removing panels and replace with PVC pipes should be a DIY level job, as the water panels were connected together via rubber 3x3" pipe flexible coupling which should be easily untightened.
    20 year old 12k Gal IG pool with SPA, Concrete white plaster, 1.0HP pump, Cartrige filter
    mas985's Avatar
    Pleasanton, CA
    11,987
    Re: Any downside of removing solar water panels and replace with PVC pipes?
    Do you not have a solar valve?
    Why not just turn them off?
    Why do you need to use any pipe? Just cap the pipes going to solar in case you ever want to add it again. But being from SJ, you will want them again.
    Mark
    Jun 2016
    San Jose
    30
    How do you remember I'm in SJ?
    I still need to run the solar system to heat the water. I need an easy and quick fix to bypass those two leaking panels. I actually wanted to replace with new panels but the solar company's handyman said the whole system needed to be scraped and quoted me a high price to install a completely new system. It didn't make too much sense.
    Quote Originally Posted by mas985 View Post
    mas985's Avatar
    Pleasanton, CA
    11,987
    Ok so what you want to do is to replace the two panels with pipe? Just use the same pipe size as the header.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Quote Originally Posted by Eric_yang View Post
    It is in your location over there <------
