Thread: water missing from pool while closed
    May 2016
    new jersey
    37
    hey guys,
    so about 2 months ago i started to think my water level had been decreasing. it was minor enough that i chalked it up to evaporation, impossible as that sounded.
    but somewhere within the last month, the water level definitely got lower. and now i think the pool cover pump i had must have been siponing water from under the cover through some kind of hole somewhere on the cover.
    the water level must be a foot lower from where it was when i closed the pool.
    it just dawned on me today that the water provides an opposing force to the ground and that my walls are in jeopardy of cracking. but it's freezing outside now and i'm not sure it's so wise to try to refill now. suggestions?
    22kgal kidney pool, concrete walls, vinyl liner
    jandy vsfhp165aut with iaqualink controller. jandy cs250 filter. jandy truclear swg. jandy ee2500 heatpump
    all versaplumb fittings throughout equipment 7 ton waterfall driven off pump
    polaris 380, powered by main pump. taylor tf100 test equipment
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: water missing from pool while closed
    How low is your actual water level currently? Relative to the top of pool and to the 'shallow end' if you have one? Unless it is really low, I wouldn't be too concerned. I would be more concerned about your liner shifting than the pools walls for now. If your pool isn't a block of ice, I would add water now for peace of mind but I wouldn't add water on top of ice though.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2016
    new jersey
    37
    down to first stair (12" from bottom of low end). yikes.
    Pool Tool's Avatar
    May 2014
    757
    Frozen solid still? I would try to add some water if possible.
    Jul 2012
    Basking Ridge, NJ
    47
    We've had a string of nice weather days, if you want to add some water I would say go ahead and do it. How deep is the shallow end where you have 12" of water remaining? Keep an eye on your cover pump and see if it starts to pump out water once the water level gets higher.
    28,000 Gal Pool w/ Attached raised Spa, White Plaster Finish, D.E. Filter - FNSP 60 sq. ft., Whisperflo Pump, Nature 2 Element (Housing Only Now Devoid of Cart.), Hayward CL200 In-Line Automatic Pool Chemical Feeder, RayPak Gas-fired Heater, Polaris 380, Zodiac 1.5-HP 240-Volt Polaris QT Spa Blower
    May 2016
    new jersey
    37
    thanks guys.
    i did refill not long after i posted. i stopped about 12 inches from filter because we were getting freezing whether and didn't want plumbing problems in the house.
    this weekend i finally got the last 6 inches done.
    i removed the pump. nearly had the cover cave in. threw the pump back on it and tided the cover up.
    whew. thanks.
    just hope the walls didn't crack.
