Thread: Dropping Water Level with Spa Running
    Mar 2017
    Laguna Niguel, CA
    2
    The spa is adjacent to the pool. The controls allow to run either the pool or the spa (single pump). When in the "pool" mode, there is water going over the spillway between the spa and the pump. Wehn everything is off, the spa eventually ends up with the same water level as the pool. Until recently, when the spa was running, there was a small amount of water going over the spillway. Now, not only is there no spillway flow, but the level in the spa drops about 4".
    There is a bypass line between the pool discharge and the spa discharge as shown in the attached photo. There is a one way check valve and a ball valve in this line. The left side is the pool side and the check valve arrow points towards the right (spa) side. The ball valve has always been open. The check valve was replaced about 8 years ago but I can't recall the symptoms that caused it to be replaced.
    The filter pressure gauge shows about 7 1/2 psi with the pool pump running. It rises to about 10 psi when the valves are switched to spa mode. I tried shutting the ball valve when the valves were in pool mode and the pressure rose to 10 psi. The volume of water going over the spillway then decreased to a very small amount but appeared to keep flowing. Closing the valve in the spa mode didn't appear to change anything.
    I replaced the seals and o-rings in the two Ortega motorized valves about a year ago after I found that the valve on the suction side was leaking air around the shaft and causing bubbles in the pool discharges. The new o-rings fixed that problem.
    As there are no holes in the 3 way valve rotors, I don't see how the spa was ever receiving "extra" water so that is had a slight spillover. I also don't understand the purpose of the bypass line, the check valve or the ball valve.
    Perhaps someone can enlighten me as to how the system is supposed to work and why it would suddenly change.
    Apr 2016
    TX
    51
    Re: Dropping Water Level with Spa Running
    Hi GLKD,
    I've had that happen to me before. The way the spillway works, basically, you only suck from the pool side, and return all (or mostly) to the spa. If the valve selecting the pool vs spa drain is leaking or stuck, this can lower your spa slowly. Same for the valve that selects pool or spa return. I'd check out those two valves and/or the actuators first. See if you can disengage the automatic actuators and manually set the valves. A failing valve actuator motor might not have enough 'juice' to move the valve all the way to the right position. Even a small leak in either f these valves will pretty quickly drain the spa. Check valve might be there for an air blower. Not 100% sure what the bypass line is there for, might be to lower the spa pressure, or for some down the line equipment that needs to lower pressure (sometimes some salt water chlorinators have flow limits, etc.). Just for reference, are you turning off your pump before running the valves?
    -Mo.
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    Mar 2017
    Laguna Niguel, CA
    2
    Hi Mo,
    Thanks for the quick reply. Unless I'm confused (entirely possible), I don't see how the spa could heat the way you describe the flow. In the spa mode, only the water from the spa is circulated through the heater, which has a temperature setting for pool or spa. If all the water was drawn from the pool, heated and then returned to the spa, I believe you would have to bring the whole pool volume up to spa temperature. With the system working the way it is now, only the spa water is heated and the pool temperature stays the same (other than a tiny rise from the spa spill over.
    There doesn't seem to be a problem with the valves operating while the pump is running. They rotate very slowly and therefore don't cause any rapid flow change. I did check to be sure that both valves were rotating fully.
    Also, there is no auxiliary equipment in the pool/spa circuit. There is a fountain pump, but its' operation is completely separate from the pool.
    Apr 2016
    TX
    51
    Hi GLKD,
    There are two modes for operation:
    1) Normal, suck from the pool, return to the spa. You wouldn't turn on your heater here, unless you want to heat the pool and spa, as you pointed out.
    2) Spa heating, suck from the spa, return to the spa through the heater.
    If either the drain or return valve is leaking, you can cross-communicate the spa and pool drain or return, leading to the effects you are seeing. Additionally, you might check to see if there's any excess water around your equipment. Heaters often leak - I have to fix mine every year or two, but the amount of water is pretty evident.
    A line diagram of your equipment, showing where the plumbing was coming and going, placement of the valves, etc, would be helpful to troubleshooting.Pool Diagram.pdf
    I've attached a sample diagram for your reference. I used MS Visio, but you can use anything.
    -Mo.
    Following...
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Apr 2016
    TX
    51
    Did you get it figured out?
