Results 1 to 10 of 10
Thread: What should I expect when I pull off the cover ?
    Feb 2017
    Danbury,CT
    23
    My pool was filled with water at the end of November. It was filled below the skimmer. The guys poured a gallon of liquid chlorine in it. A couple of days later a different crew came to cover the pool. They also poured a gallon in. Should I expect the pool water to be clear or green when we take off the cover ? What is typical ? Also does anyone know when the pool startup is in CT ? BTW possible 12" of snow Tuesday.
    Radiant Metric Pool 18'x32'x52" approx 15,000 gal. Hayward EC65 filter, Hayward SP2607X10 Super Pump
    Jan 2012
    'burbs of Augusta, Georgia
    8,587
    Re: What should I expect when I pull off the cover ?
    Well, if they closed it while the water temp was under 60 degrees, and if you open it before it hits 60 degrees, you have more chance of opening to minimum problems.
    Algae is very slow growing in cold water.
    Pull the cover off and run a full set of tests (do you have one of the recommended test kits??) and if you have green, we can walk you thru a SLAM.
    I'm hoping all will be clear and clean
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Saturn94's Avatar
    Mar 2015
    Virginia
    556
    Do you have a mesh cover or solid cover? A solid cover will increase the likelihood you'll open to a clear pool.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 w/booster pump/Hayward Superpump 1 hp/city water/Taylor test kits/pool installed March 2004
    Feb 2017
    Danbury,CT
    23
    my TF100 test kit is ordered and on its way. There is a solid cover and it was covered below 60 degrees. Its been frozen most of the winter. I have no idea when they plan on start up. We never ran the filter because the pool was finished at the end of November.
    Jan 2012
    8,587
    Great news on the test kit. Did you get the speed stir too? It sure makes testing easier (let the device swirl the sample as you add drops of reagent instead of your other hand trying to swirl and mix. Some folks are more coordinated than me..... I love the speed stir, LOL)
    Sounds like you're not going to have any problems to me. Let us know how it goes
    Yip
    Feb 2017
    Danbury,CT
    23
    Yep, getting the speed stir too. thanks
    Feb 2017
    Danbury,CT
    23
    Should I assume that the cya will be 0ppm ? nothing was added except a couple of gallons of liquid chlorine. amazon has Clorox Pool & Spa 10004CLX Chlorine Stabilizer, 4 - Pound for $12.77
    So you think that I should order it while it is on sale ?
    May 2011
    lebanon tn
    370
    Bought 4 lbs at Walmart I think under $10 last week
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    domct203's Avatar
    Jun 2015
    CT
    3,912
    Still a bit early in our neck of the woods, but I believe I picked up 4lbs of HTH brand stabilizer for about $13 at Walmart last year.
    Also, Ocean State Job Lot is a great source of 12.5% liquid chlorine. It's been $2.99 a gallon for the past two seasons, with $10 cases of 4 jugs occasionally. Always fresh at my store.
    Stay away from their stabilizer though, I tried it my first season and it takes forever to dissolve, and I would always find stones/course sand in the sock after the CYA was dissolved.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    NOW you tell me about the stabilizer at Job Lot. I bought two containers of it in the fall when it was 50% off or something like that. Still for only 4bucks for 4 pounds I can handle it being slow to dissolve. I've been getting itchy to open my pool, in southeastern CT, but the weather this past week and a blizzard tomorrow sure changed my mind about that. I don't think I will be pulling my cover till the last week of april or early may.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
