Thread: Easytouch install - DIY? Yes or No
    Is the easytouch load center very hard to install and setup for a 2 speed whisperflo pump and a intellichlor SWG? I'm trying to decide if I want to get the easytouch or a less functional (and less $) intermatic time clock to handle the 2 speed pump and booster pump.
    Thanks for your help.
    19,600 to 22,500 gallon plaster pool. (Every calculator is different)
    1 1/2 hp pump Don't know the flow rate
    48 sq. ft. DE filter
    Polaris 280
    Real POS Laars LX Low NOX 400k heater (5 years old and it's DEAD)
    rlvogel322's Avatar
    Jul 2007
    La Crosse, Wisconsin
    9
    Re: Easytouch install - DIY? Yes or No
    I just finished installing an Easytouch. I don't have a SWG or InteliFlo but it was pretty straight forward. You will need some electrical experience and if you're not comfortable with sub-panel installation I would recommend an electrician install it.
    20x40 35k IG vinyl liner pool with automatic safety cover
    Pentair Whisperflo 1.5 HP pump - Pentair TA60D sand filter - Pentair MiniMax NT 300 - Liquidator
    Thanks for the reply.
    I wanted to make sure I didn't have to have a PhD in Pentair to make everything talk.
    I guess there is always tech support if needed.
    Thanks again.
    Polaris 280
