Thread: K-1766 results differ significantly from Aquapure? Temp change causing it?
    May 2016
    Dallas/TX
    331
    pH 7.8
    Chlorine 11.5 PPM (lowered SWCG from 40% to 30%)
    Calcium Hardness - 275PPM
    CYA 80 PPM
    TA 90 PPM
    Salt 2200 PPM via K-1766
    Aquapure says 3.1 g/l.
    DFW just experience a significant cool down over night... is this possibly screwing with the chemistry? Went from 70F to 45F.
    Thanks! (Hoping pooldv stops by )
    12K Gallon, IG PebbleSheen Blue Granite, built AUG 2016, 4 Jandy nicheless LED lights , Jandy 2.0HP VS ePump, Jandy AquaPure PLC700 SWG, PB4-60 Booster pump, Polaris 280, Jandy CV580 VersaPlumb Cartridge Filter , Jandy - Pro Series RS4 W/iAquaLink, Jandy JXi400NK 400K Heater, OK Flagstone Coping, Travertine Decking, 7 x7 Spa, Tanning Shelf, 10' Grotto, TF-100.
    Re: K-1766 results differ significantly from Aquapure? Temp change causing it?
    What temperature is the water and what temperature does AquaPure show?
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    I always trust my K-1766 over the SWG reading. Take a sample inside if its cold and let it warm up for an while then re-test the salt and see if its different.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
