Results 1 to 7 of 7
Thread: Borates
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Borates
    I feel like I've gotten my testing methods and pool maintenance under control. I was reading about Borates and I just wanted to type this out to make sure...based on my calculations for my pool size, I would need over 130 lbs of the 20 Mule? That can't be right can it???
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Borates
    According to my PoolMath results to go from 0 to 50 ppm in 20k gallons I get
    1177 oz borax or 73-1/2 lbs, I think the boxes at the grocery store are around 4 lbs, so 19 boxes. Might need to hit a couple of stores for that.
    561 oz muriatic acid or 4.4 gallons
    Or you can order 764 oz of granular boric acid from Dude Diesel. Or 47-3/4 lbs. Which is handy because they sell a 55 lb bucket.
    Have you read this article?
    Borates - Why and How
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Re: Borates
    I highly recommend the boric acid from Duda Diesel. You don't have to add the muratic acid, and once I ordered it, we received it just a couple of days. Great service!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    slinkyra531's Avatar
    Jun 2013
    Millville, PA
    35
    Re: Borates
    I used the Boric acid from Duda Diesel and i highly recommend going that route. It will cost you roughly the same amount of money but a lot less time. Plus you will have some left over so you can make the small maintenance additions every once in a while. Be sure to get your PH set before you add it. It wouldn't hurt to have your PH a little on the high side because the Boric acid will lower it slightly.
    24'x52" Above Ground Pool, Hayward Sand Filter, 1 HP Hayward PowerFlo Matrix Dual Speed pump, In-line Chlorine Feeder (only used when on vacation), AquaLuminator return light (customized with color changing LED light), all plumbing done with Schedule 40 PVC
    & 2004 Elite Spas Monterey Hot Tub (~400 gallons) with Controlomatic Technichlor SWG - Use Taylor K-2006 test kit with K-1766 addition and speed stir on both.
    Uncle Salty's Avatar
    Feb 2017
    South Carolina
    222
    Re: Borates
    I ordered from Bulk Apothecary, $13 cheaper for the 55lb pale than Duda Diesel.
    20X40 30,000 gal. Vinyl, AquaPlus Automation w/ T-15 SWG & AquaConnect, EcoStar SP3400VSP pump, ProSeries S310T2 Filter, H Series 400FDN Heater, Sense/Dispense with Stenner Pump, ColorLogic X 3, TigerShark RC990, ​Borates, TF-100 test kit, K-1766 & Speed Stir Finally done! Well Almost
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Borates
    Check eBay, granular boric acid, bag can be found cheap.
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Re: Borates
    I did read that article but totally did the calculation wrong. Thanks everyone, the 55lb bag of Boric acid seems the way to go, that way I don't have to mess with MA.
    Memphis, TN.
    Taylor K-2006
