Results 1 to 8 of 8
Thread: Threading is stuck
    Jul 2013
    Long Island, NY
    557
    Threading is stuck
    Help I was fiddling around with attaching my slice valve onto a part of my filter. I guess I tightened too hard and now I can't undo it. It's abs plastic. Any ideas?
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Re: Threading is stuck
    Try warming the female part with hot water to get it to expand. Maybe put some dish soap or spray lube (silicone, teflon) into the threads.
    A hairdryer or other heat can be used but don't overheat.
    Support the site
    Jul 2013
    Long Island, NY
    557
    I tried dish soap and then I tried silicon couldn't get it. It's pretty tight. I'm ok if its stuck HOWEVER I didn't add Teflon tape to it. Is there a chance it will leak
    SWG: Intex CS8110
    If you didn't use any type of sealant, it won't be water tight.
    Try heating the female part.
    If you have channel lock type pliers, you should be able to get it apart.
    Support the site
    Jul 2013
    Long Island, NY
    557
    thanks for the suggestions. actually when my wife got home we both held each side with 2 hands and it unscrewed, I don't know how I got it so tight
    SWG: Intex CS8110
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Plastic pipe binds together with no thread seal/lube. Teflon tape also acts as a lubricant in addition to a sealant.
    Essential Links:
    Jul 2013
    Long Island, NY
    557
    Patrick - Interesting I did not know that. I won't make that mistake again
    SWG: Intex CS8110
    Also note that static friction is greater than kinetic friction. While moving, it takes less force than when stopped. That's why it takes more force to get it to come apart than it took to get it together.
    It's the reason for antilock brakes. If the wheels lock, the tires slide across the road vs being static with respect to the road.
    Support the site
