Results 1 to 9 of 9
Thread: Pollen affecting CC results?
    Uncle Salty's Avatar
    Feb 2017
    South Carolina
    221
    Just curious if the high amounts of pollen can affect test results regarding CC? I read that if your CC measures higher than .5 it's a indicator of issues, however my water is crystal clear other than you can see pollen collecting along the walls. Does this call for a slam or just let it run its course keeping my FC where it's at? Here are my results from earlier.
    FC 6.3
    CC 1.2
    PH 7.5
    TA 128
    CH 68
    CYA 73
    Temp 68*
    Salt 3100
    This the first time I've had anything over the .5 level.
    20X40 30,000 gal. Vinyl, AquaPlus Automation w/ T-15 SWG & AquaConnect, EcoStar SP3400VSP pump, ProSeries S310T2 Filter, H Series 400FDN Heater, Sense/Dispense with Stenner Pump, ColorLogic X 3, TigerShark RC990, ​Borates, TF-100 test kit, K-1766 & Speed Stir Finally done! Well Almost
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Pollen affecting CC results?
    A number of folks use a skimmer sock to help with pollen. Pollen is organic and CCs come from FC breaking down organics. So I bet that's what's going on.
    During pollen season I put a paint strainer on my skimmer basket. The rest of the year I use hairnets.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Feb 2017
    South Carolina
    221
    Quote Originally Posted by pabeader View Post
    Thanks for the response. I do have skimmer socks, I'll put a couple on tomorrow. So I don't need to worry or slam then?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    I'd just bump up FC a few points and see how it does.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    If your water is honestly clear all the way to the deep end, then I would say you are okay. There is no harm in doing the SLAM if you want to.
    Feb 2017
    South Carolina
    221
    Yes clear to the bottom in the deep end, can see the main drains clear as can be. I don't want to slam but wanted reassurance of that. I'll keep testing daily and keep a eye on it, thanks.
    Quote Originally Posted by woodyp View Post
    Will do, I actually turned back my SWG as the FC was up to around 8.5, I'll put it back where it was. Thanks.
    Jan 2012
    'burbs of Augusta, Georgia
    8,561
    And don't forget to brush those walls now and then to get the pollen into circulation so the filter (or skimmer sock) can collect it.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Feb 2017
    South Carolina
    221
    Quote Originally Posted by YippeeSkippy View Post
    Yip
    Oh I've been brushing, my shoulder reminds me how much every morning. Does it also seem normal to have to backwash more? I backwashed Wed and went out this morning and had zero flow on my filter. I just backwashed again and flow seems good again, I do get a lot of tree debris and such.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    Skimmer socks get rapidly clogged from pollen and can reduce flow significantly. They need to be checked daily or more often during peak pollen season. That could be part/most of your flow issue. The first time I used them I think I went two days and my pump started cavitating from lack of flow. I now use hair nets all the time (for pollen, small debris from by leyland cypress and dog hair). The are disposable so you don't have to rinse them out like skimmer socks.
    https://www.amazon.com/Disposable-Ha...002XK2FS0?th=1
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
