Thread: Opening salt pool for first time
    May 2016
    Troy, ON, Canada
    1
    Red face Opening salt pool for first time
    I converted to salt at the end of last season. Just love it ! This is the first time I have opened with this setup. Is there anything I should do different vs a regular chlorine pool ? Located in Ontario, Canada.
    18k gallon, 16x32, salt (recently converted),Vinyl liner, Hayward Superpump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,281
    Re: Opening salt pool for first time
    C,
    Welcome to TFP... A Great resource for your saltwater pool questions...
    I can't think of anything different. In my case (Pentair SWCG) I don't trust the internal salt test until the water temperature gets into the low 70's.. It reads lower than the actual salt level.
    If you don't have one, I recommend getting a Taylor K-1766 salt tester.
    Not sure of your water temperature, but my SWCG won't produce any chlorine below about 52 degrees.
    Thanks for posting,
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Keep an eye on your PH as a SWG will cause that to rise.
    Saturn94's Avatar
    Mar 2015
    Virginia
    554
    Don't use the SWCG to bring FC up or to "shock" the pool. Just use plain bleach/liquid chlorine. Once your done with spring cleanup and FC holds overnight, then you can turn on the SWCG to maintain proper FC.
    Using the SWCG only to maintain FC will increase cell life.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 w/booster pump/Hayward Superpump 1 hp/city water/Taylor test kits/pool installed March 2004
