Thread: Test Kit Upgrade
    wrightwolf23's Avatar
    Apr 2016
    Sumter, SC
    6
    Test Kit Upgrade
    So. I have a Taylor 2005 test kit and very much need to move to FAS-DPD testing.
    My instincts don't really want to buy the full Taylor 2006 kit or any other full range test kit, but I am trying to figure out if I need other than the FAS-DPD reagents.
    it appears to me that I will need a new comparator (?) along with a FAS-DPD reagent refill kit...for sure they package the two kits with a different comparator, I just don't know if the measurement it gives is any different (?)
    It appears to me everything else about these two kits is essentially the same? Can someone give me experienced advice on this?
    Thanks much!
    /chuck
    Components for Kit Number: K-2006
    Component Description Quantity
    2004B BOOKLET,POOL&SPA WATER CHEM,2011 ed. 1
    5138 K-2006 SERIES INSTRUCTIONS 1
    6026 WATERGRAM,CIRCULAR 1
    9058 2000 SERIES COMPARATOR BR&CL FAS-DPD/pH 1
    9191 BOT,CA DISP,7&14ML,PL W/CAP 1
    R-0003-A DPD RGT #3; .75 OZ DB 1
    R-0004-A PH IND SOL (PR);.75OZ DB 1
    R-0005-A ACID DEMAND RGT (ADR);.75OZ DB 1
    R-0006-A BASE DEMAND RGT (BDR);.75OZ DB 1
    R-0007-A THIOSULFATE N/10; .75 OZ DB 1
    R-0008-A TOT ALK IND; .75 OZ DB 1
    R-0009-A SULFURIC ACID .12N; .75 OZ DB 1
    R-0010-A CALCIUM BUFF; .75 OZ DB 1
    R-0011L-A CALCIUM IND LIQ; .75 OZ DB 1
    R-0012-A HARDNESS RGT; .75 OZ DB 1
    R-0013-A CYA RGT;.75OZ DB 2
    R-0870-I DPD PDR; 10 GM V 1
    R-0871-A FAS-DPD TTR''G RGT; .75 OZ DB 1
    Components for Kit Number: K-2005
    5136 K-2005 SERIES INSTRUCTIONS 1
    9056 2000 SERIES COMPARATOR CL/BR DPD/pH 7.0-8.0 1
    R-0001-A DPD RGT #1; .75 OZ DB 1
    R-0002-A DPD RGT #2; .75 OZ DB 1
    15,200 gallon AG 24'x52"/Hayward Pro Series 21" Sand Filter 1.5 Hp Power-Flo LX/Well
    30,961
    Re: Test Kit Upgrade
    Here's all you need. It's not beautiful but it is a perfectly functional FAS/DPD kit
    TFTestkits.net
    Apr 2016
    Sumter, SC
    6
    TFTestkits.net
    I had thought about that route also before I started my comparison of the other reagents in the two Taylor kits. Looking deeper I can see you are correct.
    Thank you sir!
