Thread: Jet eyeball ring removal pool
    Jul 2015
    Cresskill, NJ
    7
    I believe there's a tool out there that could assist me in getting the "ring" off of this eyeball jet. (see pic). Each time I try to use either channel locks or pliers -- a piece of the plastic breaks off. I saw a video online where someone removed one of these with a simple tool - I think they referred to as the "blue tool". However, since that's not the real name -- I don't know where to find it or what to search for. Please let me know if anyone has some thoughts! Thank you.
    2012 built kidney shape, IG, plaster approx 30,000 gallons. SWG system with a DE filter
    Apr 2015
    South Central PA
    298
    Re: Jet eyeball ring removal pool
    There is a special tool from Hayward, but I just use a steel putty knife...
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    domct203's Avatar
    Jun 2015
    CT
    3,900
    If there is slots inside that fitting, this is the tool:
    https://www.amazon.com/Hayward-SP141.../dp/B003VSO1PI
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2015
    Cresskill, NJ
    7
    Thank you for the replies! I'll give it a try.
