Thread: Losing Water over Winter?
    Jun 2016
    parlin
    79
    Hi everyone!
    My husband has been noticing that the pool is losing water. I believe when we closed it, it was a few inches below the skimmer, and now he says that it's at least a foot,maybe more under the skimmer, so there's something wrong. He went out looking around last night and I asked him if he saw any wet spots, he said no. I figured if there was a leak or an issue with the liner, that there'd be some kind of puddle or wet spot. Or is it just normal that the pool loses water while being covered?
    I know we have a 1 year warranty on the liner, which would be May 5th, but he doesn't want to open the pool that early. But if there's any issue with the liner, I'd like to find out before the warranty is up, not after.
    Beth Russo
    Central NJ
    Bought a 16 x 32 Hampton Oval Above Ground Pool from The Pool Factory in May 2016. 15,000 Gallon Pool. Overlap Blue liner - 25 Gauge. AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump 2 Year Warranty.
    banditig's Avatar
    Sep 2015
    Ohio
    468
    Re: Losing Water over Winter?
    Here in Ohio, my pool with cover gained water. You might have a leak at the return fitting (very common). Or the level will stop were the leak is if its a hole in the liner at the sidewall.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Its possible that heavy snow on your cover displaced the water in the pool and pushed it out the return fitting or skimmer. I know I lost a good 4 inches of water from that after we got about 14inches of very heavy wet snow. You could also have a small leak. I would measure the level of the water from the top rail when the cover is pumped as dry as you can get it then keep a close eye on the water level. To see if there is a leak or not. If the water level is really low and the cover isn't being supported by the water in the pool you will either want to refill the pool or take the winter cover off. There was a thread not too long ago where a pool was severely damaged from a pool cover full of snow after the water in the pool drained from a leak in the liner.
    https://www.troublefreepool.com/thre...ve-ground-pool
    If you think it is a warranty issue open a dialog with whoever your warranty is with and get some proof in writing that you brought the issue up with them before the warranty period expired.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Same here, with all the rain & snow, the cover displaced a good 3" or so from the pool.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
