Results 1 to 10 of 10
Thread: Ionizer to replace aquarite ?
    I didn't see a forum specific to ionizers . Apologies if this is in the wrong place.
    I have and aging aqua-rite system with a salt cell(t-15) that is likely going to maybe make it through summer( #2 cell).
    Before i purchase a new cell, ive seen some information on Ionizers , and im wondering how effective this technology is.(10k gallon play pool in phoenix az area)
    interestingly a friend has a pol with the same set of circumstances, though his cell is dead.
    Looking to see if there are new and better alternatives to salt generators.
    the one ive seen talked about the most is; http://www.ecosmarteusa.com/
    Thanks
    Re: Ionizer to replace aquarite ?
    Probably not going to find much support here for ionizers.
    Support the site
    domct203's Avatar
    Jun 2015
    CT
    3,909
    I believe you still need a residual sanitizer (chlorine) when using ionizers.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,310
    Brando,
    If you read closer you will find that this system slowly dissolves a bar of copper into your pool water and it uses the copper as the algaecide. Not something I want to be swimming in. You might also note that to use their system they want you to keep your pH between 6.8 and 7.2.
    The say... "...That's right, no burning eyes, no dried out hair, no cloudy water, and no toxic smell. Your swimming pool or spa will have pure, crystal clear, chemical-free water and require a lot less effort and expense...."
    Well, as soon as my saltwater pool burns my eyes, dries out my hair (what little I have), turns cloudy, or starts to smell.... I'll give them a call.
    You might also note where they say something like "... if your pool does get algae, we recommend that you should dump in a bunch of chlorine..."
    Thanks, but no thanks.. I'll just stick to what is working for me.
    Donldson's Avatar
    NW Ohio
    3,219
    There is no sub-forum for ionizers for a very good reason: ionizer = metals = Not TFP recommended. Any copper or silver system can cause staining of the pool or a swimmers' hair (blonde hair plus copper makes green hair) and copper has zero anti-microbial properties. Any system that only uses an ionizer and no chlorine is not safe.
    If you do a search for EcoSmarte specifically you will find plenty of threads here. They all say the same thing: avoid.
    Sent with Tapatalk on HTC Ten
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Oct 2007
    Parkland, FL
    753
    They work, I used one, it was fantastic for 6 months, pool was crystal clear, not a drop of chlorine. The problem is if anything happens and it slightly gets algae, the system can't keep up and you will have to majorly add chlorine till every last bit of algae is gone. A salt generator is so much easier and less maintenance. The ionizer rods burn down pretty quick too.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Jan 2012
    'burbs of Augusta, Georgia
    8,587
    Quote Originally Posted by robl45 View Post
    Yet you were swimming in copper laden water, and hope no one with a herpes outbreak or some other disease wasn't sharing it with you in water that wouldn't kill the cooties.
    And eventually that copper is going to stain the pool walls and turn hair green as it builds up.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    Post #15 in this thread explains the slow kill times for bacteria and other pathogens. converting my ecosmarte system to chlorine
    Algae prevention with copper or silver is the old technology, first used a couple of thousand years ago. Chlorination is a bit over 100 years old, and SWGs for residential pools about 40 years old. In this case, you'll have the least trouble if you stick with the newer technology
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Thanks all for the replies, i have seen the light, staying with the Aqua-rite and replacing the cell(which we found we can use a T-3, so cheaper, correct firmware and pool size of 11k)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    There is a downside to using the T-3. It produces less chlorine/hr so it will need to be on more. Since the cell only has a certain life, the more you run it, the sooner it will need replaced.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
