Results 1 to 8 of 8
Thread: How long to wait after start-up before we can use heater
    Mar 2017
    Houston, TX
    86
    Hello, we just built a new pool two weeks ago. We have a 400k BTU Pentair heater for our almost 22k gallon pool. I've read that we should wait to use the heater, but how long should we wait? We have quartz plaster finish on our pool.
    Thanks for any feedback!
    First time pool owner
    21K IG; quartz plaster finish
    Pentair 1HP Whisperflo pump; Pentair Clean and Clear Plus cartridge filter; Pentair Mastertemp 400K BTU heater
    Polaris 280; Completed Feb. 2017
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: How long to wait after start-up before we can use heater
    30 days from fill.
    Mar 2017
    Houston, TX
    86
    Is it to not use the heater at all? Would it make a difference if we set it to a lower temp like 80 vs going up high? We don't have a spa... looking at our spring break weather next week and it looks like it's in 60's and low 70's!
    Jan 2012
    'burbs of Augusta, Georgia
    8,571
    Did your pool builder say anything about using your pool cleaner too? Some pool builders warn not to use cleaners for a month if they have rolling wheels while plaster is new to avoid marring the new plaster.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,155
    30 days-----------------no use.
    domct203's Avatar
    Jun 2015
    CT
    3,896
    Not only should it be off, it would be best if it was bypassed, especially if the PB used an acid start up.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mar 2017
    Houston, TX
    86
    Ok we'll wait to use it then. Is it b/c the plaster is still soft and curing? Just curious. And yes, we were told to wait on running the vacuum, but said just a couple of weeks for that.
    Our start-up tech turned off our pumps during the acid start up, so hopefully none of the equipment was affected.
    ps0303's Avatar
    Jul 2011
    FL
    3,921
    Quote Originally Posted by JuYuHu View Post
    Just depends on how they did the acid start up. Your pool heater should never have been plumbed into the system unless they had a bypass setup to prevent the water from going thru it until the water was stabilized.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
