Thread: Brown Slime
    Jan 2016
    KS
    63
    Brown Slime
    I have a standalone spa and noticed I am getting a brown slime forming all over the handles and on the bottom of the cover. This is only happening in areas outside of the water. Anyone know what the cause is (I have read High PH) and how to get rid of it and prevent it from happening again? Hot tub does not get used often right now but when I check PH it is always in line and bromine is good (Although it dropped to 1) once when I forgot about it.
    36,000 Gallon, 40x20 IG, Vinyl, Hayward S- 200 Sand Filter, 300,000 MasterTemp heater, 1hp Superpump, Polaris 9550 sport, TF100 test kit
    JoyfulNoise's Avatar
    May 2015
    14,091
    Re: Brown Slime
    It's probably mold growing from the humidity under the cover. I'd remove the cover and sanitize with a mild bleach spray. Then, you should open the cover on a regular basis to let the humidity out.
    Matt
    Re: Brown Slime
    Could be organics, body oils etc that cause foam. The foam can create sticky goo.
    Do you get much foam?
    Support the site
