Thread: Pump Wiring
    Sep 2015
    FL
    24
    Pump Wiring
    I bought this pump a while ago and had it hooked up 110VAC. Done some reading and decided I needed to move it to 220VAC. I thought I still had the wiring instructions but can't seem to find them now. Google search results for the pump have not been fruitful.
    Anyone have one or can look at the sticker on the pump and correlate to what goes where on the pump for 220?
    Pool: In-ground, Kidney Shaped, Unknown Size, Sand Filter.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pump Wiring
    If the pump is running fine on 110v there is generally no compelling reason to switch to 220v. It will consume the same amount of power regardless of voltage. What is your reasoning for wanting to change?
    The instructions for wiring the pump are in the pictures you posted. To switch the pump to 220v the black wire on post 3 moves to post 6 and the white wire (7) to post 3. The pump as it is pictured now is set up for 110v.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Sep 2015
    FL
    24
    Re: Pump Wiring
    Thanks CJ.
    I I'll stay with 110.
