Thread: Pentair IC60
    Jun 2014
    Iowa
    17
    Pentair IC60
    Planning to add the IC60 this spring. Do I need EasyTouch to run it, or can it just run off of the basic mechanical timer that currently runs the pump?
    25,000 gallon inground plaster pool with attached spa. Sand filter.
    May 2016
    Northeast MA
    139
    Re: Pentair IC60
    You do not need EasyTouch to run it. You will not have the 1% increment adjustability that you can get with EasyTouch, I think you're limited to either 10% or 20% increments, not positive, but someone else will have that answer. You can run it off the same timer that you have that runs the pump.
    Inground vinyl 23'x40' Aspen shape, ~27K gallons, Sta-Rite Intellipro 2 VST Pump, Sta-Rite System:3 Mod DE Filter (60 sq ft), Hybrid In-Floor System (Paramount Valve with Caretaker Heads), AquaComfort Heat Pump, 3x Savi Melody Sol 28W LED Lights, Pentair IC60 SWCG, EasyTouch Automation with ScreenLogic, TF-100 test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pentair IC60
    Yes, you can run the IC60 on a mechanical timer. And yes, the output can only be changed in 20% increments. 20, 40, 60, 80, 100. Mine is wired directly to its own mechanical timeclock and it is easy to control the output by changing the percentage and the on time. Just make SURE that the SWG only runs when the pump is running.
    Mar 2016
    Chino Hills, CA
    190
    Re: Pentair IC60
    Our neighbor recently got an IC40 in their 10k pool without the EasyTouch. They run their pool pump 6 hours a day and the FC is way to high at the lowest setting of 20%. Having the EasyTouch makes it much easier as you could dial it down further than 20%.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    Re: Pentair IC60
    0% No LEDs lit - No chlorine produced - IntelliChlor SCG is off.
    2% 1 LED blinking Produces chlorine for 64 seconds of every hour.
    4% 2 LEDs blinking Produces chlorine for 127 seconds of every hour.
    6% 3 LEDs blinking Produces chlorine for 16 seconds of each 5 minute period.
    8% 4 LEDs blinking Produces chlorine for 21 seconds of each 5 minute period.
    10% 5 LEDs blinking Produces chlorine for 27 seconds of each 5 minute period.
    20% 1 LED solid Produces chlorine for 53 seconds of each 5 minute period.
    40% 2 LEDs solid Produces chlorine for 106 seconds of each 5 minute period.
    60% 3 LEDs solid Produces chlorine for 159 seconds of each 5 minute period.
    80% 4 LEDs solid Produces chlorine for 212 seconds of each 5 minute period.
    100% 5 LEDs solid Produces chlorine for 265 seconds of each 5 minute period.
    The new cells allow lower % output.
    Verify that the cell you get has the lower settings.
    Support the site
