Thread: Salt
    Sep 2016
    Kunkletown,Pa
    80
    Salt
    I seen a lot of old post about this. any change on this what salt to use
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Salt
    I'm not sure what you mean precisely, but Salt is Salt. If it isn't dirty, and doesn't contain additives say for a water softener or such, then it is fine for pools.
    Essential Links:
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Re: Salt
    Salt can come from different sources.
    One is to evaporate saltwater from a source like the ocean or dead sea. This is then strained to a degree through filters, but there will be some things left in it. If your pool salt bag says something like 99.0% pure, like this one, then that is probably the process used. So there are some contaminants in there, but not a big deal.
    Another method is to get salt from a salt mine. In this case it does not contain the contaminants of the salt water. So these will list something like 99.8% pure, like this one here.
    Your filter should take any of the contaminants (i.e. broken down shrimp) from the salt water salt. Could it add to some buildup on your salt water cell? Not sure. I went with the purer salt to set up my pool as the total cost difference was pretty small.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Sep 2016
    Kunkletown,Pa
    80
    Re: Salt
    Thanks. A pool store was telling me aquasalt. Is better but double the price.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Re: Salt
    Actually my pool builder recommended non iodized 99% pure granular salt. Luckily I get that REALLY cheap.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Re: Salt
    Quote Originally Posted by jetfan101 View Post
    I used aquasalt for my initial fill and at my local pool store it was only slightly higher than getting the less expensive and lower %age at the big box store. I have only used my pool store once for testing - that was before I found TFP, but like them in general. Their prices are good and they do not push anything. Of course prices can vary quite a bit at stores.
