Thread: Construction-Negative Edge Design Calculations
    Mar 2017
    australia
    2
    Cool Construction-Negative Edge Design Calculations
    hi everyone. i have some questions thanks.
    I am in the process of a small wet edge pool project , curved wet edge out of ground 1.2 mts high 6 meter wet edge, 17 square meter surface area of pool.
    I have a catch basin size of 8m long by 600 wide 400 deep plumbing will be 60 mm pipe.
    How do i size the pump & is the basin big enough?
    It is still in the planing stage so i can change the basin if need be.
    Also pipe work under slab, is it the norm to encase it in concrete or cut it in the ground?
    Returns will be in the floor. Is there some method of sealing around the pipe through the slab.
    Floor will be 200mm thick with n12 rebar 200 central each way.
    I am building the wall out of 200 h blocks same steel 200 each way & core filled.
    I also plan on a skmimer & floor suction so i can convert it to a normal pool if needed.
    Thanks
    Last edited by kimkats; 03-09-2017 at 06:56 AM. Reason: Reformatted for easier reading-Kim TFP MOD
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: concruction
    Hey King,
    Welcome to our forum!
    These are hard questions for most of us here to answer as the vast majority are just pool owners. Perhaps someone here can help or direct you to a resource for it, but I wanted to say hello and welcome you aboard.
    Essential Links:
    Mar 2017
    australia
    2
    Re: concruction
    thanks for your reply. great forum by the way,
    Apr 2015
    tucson, arizona
    1,312
    Re: Construction-Negative Edge Design Calculations
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    That's a great article. I skimmed after the first few pages but quite informative.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
