Thread: How to figure out run time for pump? Pentair 1HP Whisperflo, single speed
    Mar 2017
    Houston, TX
    86
    Hi, I am new to pool ownership and this forum.
    1) We just built our pool and I'm wondering how to figure out pump run time. Our pool tech told us about one hour for every 10 degrees, but I'd like to find a more precise timing.
    2) Is there an ideal time of day to run, i.e. overnight or during the day when we may swim?
    Thank you!
    First time pool owner
    21K IG; quartz plaster finish
    Pentair 1HP Whisperflo pump; Pentair Clean and Clear Plus cartridge filter; Pentair Mastertemp 400K BTU heater
    Polaris 280; Completed Feb. 2017
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    Re: How to figure out run time for pump? Pentair 1HP Whisperflo, single speed
    Ju,
    There really is no one answer...
    Each pool is a little different... You generally run a pump for three reasons:
    1. To keep surface debris moving and being pushed into the skimmers. The more debris the more often you need to run the pump.
    2. You'll need to run it long enough to generate the amount of chlorine needed. In your case via your 3" tab chlorinator..
    3. To circulate the water to ensure the chlorine is effectively distributed throughout the pool. Two or three hours per day is all that is needed for this to happen in most pools.
    Your pool tech's "guess" is just as good as anyone else's guess..
    The only valid way to tell is to measure your CYA level and run the pump long enough to generate the level of FC (Chlorine) required based upon this chart... https://www.troublefreepool.com/cont...art-slam-shock
    Thanks for posting,
    Mar 2017
    Houston, TX
    86
    Ok, I will have to try it out and see then. Thanks for the reply!
    mas985's Avatar
    Pleasanton, CA
    11,987
    Quote Originally Posted by JuYuHu View Post
    I don't believe there is any scientific basis for that so I would ignore that advise. I run for 2 hours when the water temp is 60-70F. 4 hours when it is 80F+ but not because of water temperature but because of solar.
    Start at 4 hours and if everything is satisfactory, reduce run time until you see too much debris on the surface or you can't maintain FC levels.
    Mark
