Results 1 to 11 of 11
Thread: Question about piping for a new build
    Feb 2017
    annapolis, md
    9
    I was talking with a PB today and I'd like to get the forum's views on this issue. I had read that you should only use ridgid PVC pipe and not flexible pipe. The rationale is that the flexible pioe is easier to damage ( because it is less strong than the ridgid pipe) and it is susceptible to termites. The PB i spoke with today said that he likes to use it because you get better water flow and the vast majority of it is encased in concrete anyway. He said he would use which ever pipe I wanted. I was just wondering what the thoughts were of the folks in this forum. Thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: Question about piping for a new build
    I just don't understand how you supposedly get "better water flow" out of the same inside diameter pipe (ID) regardless what it's made of.
    Nov 2011
    Moberly,MO
    1,025
    Woody you get better flow out of flex if you don't know about a pipe oven and how to bend rigid pipe.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2010
    East Texas
    10,158
    I think I see the problem now! But we're still talkin' pvc I think!
    Go with ridged PVC. As long as it’s sized correctly, it will be fine.
    Support the site
    onlyjeeps's Avatar
    Jan 2013
    Middletown, DE
    24
    I would guess the PB is speaking in general terms about better flow meaning rigid PVC requires elbows (if you don't heat and bend which most PB's won't) versus flex you just curve instead of using 90's. Every 90 degree bend restricts flow...going back to James's point of if sized correctly there will be no problem. I can't speak on flexible pipe being susceptible to termites or the overall longevity of it since flex is used almost exclusively in above ground hot tubs, think the $4k+ ones you can buy at the store. What I can tell you for sure is that flexible PVC is at least twice if not 4 times the cost of rigid and I'm sure the PB will pass that cost along.
    23K gal, 20'x40' plaster freeform w/ spa Sylvan 2011 pool. Rheem Raypak 400K Digital NG heater, Jandy PlusHP 2.0 pump, Jandy 48sqft DE filter
    Feb 2016
    Atlanta, GA
    145
    I would go with rigid pvc and fittings. Two 45's instead of 90's to reduce flow restriction (or the long sweep 90's) if that is a concern.
    It's common practice but I never liked baking and bending rigid pvc, seems like it should weaken it some.
    Nov 2011
    Moberly,MO
    1,025
    We have been bending pipe for installs for twenty years now I guess. I would put a bent pipe in before I would use a fitting. Sch 40 is very resilient and heating it is a great way to eliminate glue joints
    Heat bending is a good way to avoid 45s or 90s. However, there is a skill to doing it correctly. If someone knows how to do it, it works well.
    Support the site
    Apr 2015
    tucson, arizona
    1,312
    Feb 2017
    annapolis, md
    9
    Funny enough that is exactly the web article that started me down this path. The other thing the builder mentioned that I didn't add earlier is the freeze and thaw issue. In reading some of the posts and an another older thread in this forum it seems this may in part be a north/south thing that changes the pros/cons ratio. Since we are in Maryland we never know if we are quite north or south!
