Thread: Weir board replacement
    Mar 2017
    Sanger, CA
    13
    I'm looking for some help replacing my weir board. My pool was built in 1991, I've own this pool for 2 years. The weir board has been missing since I moved in. Under the skimmer lid it says "sta-rite" and "U-6". I ordered p/n: 8650-0022. This is a Pentair product but it also says "sta-rite" and "U-6" on the new package. The new board is on a hinge at the bottom of the board, with one mounting screw in the middle of the hinge. I don't see a hole in the bottom of my skimmer where the board is supposed to mount. My skimmer has 2 holes, one at the bottom of the left and right wall. Did I order the wrong board?
    30,000-35,000 gal. (not sure), in-ground, short diving board, pebble tech, Nautilus FNS60 DE filter, Pentair VS pump, in-floor (abandoned) cleaning system, 2x suction "The Pool Cleaner" vacuum
    Kouri's Avatar
    Feb 2017
    Central Florida
    84
    Re: Weir board replacement
    I had the same situation and had the same problem! There is a replacement weir made that is spring loaded but, like you, I bought the manufacturer's version. I solved by detaching the new weir from the bottom piece (which gets mounted to the pool) and my husband took the original/existing piece off the pool. We then put the weir on the newly removed mounting piece and he reinstalled. We needed a stubby Philips to do this but was easy enough.
    Good luck.
    Susan
    Seasonal pool owner using pool service.
    6300 Gallon Oval In-ground Quartz Aggregate Gem Finish.
    Hayward MaxFlo Pump.
    Hayward Star Plus Filter. Pentair Star Plus Model 320 In-Line Chlorinator.
    (1) Floor Drain, (1) Skimmer, (3) Jets, TF-50 Test Kit, Oakton pH2
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    When I look up that number 8650-0022 I am getting the U-3 model. I think you need one more like Pentair 516252
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mar 2017
    Sanger, CA
    13
    I found that part number after I ordered the one that I have. The measurements seem correct. I think I'll order the 516252. I just wanted to make sure I wasn't missing something. Thanks for your help, guys and gals!
