Thread: Stenner Flow Indicator
    Mar 2013
    CT
    363
    Does anyone that has a Stenner pump use a flow indicator? I'm thinking it might come in handy to see if bleach is flowing given the tubes are black...
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    22,701
    Re: Stenner Flow Indicator
    The flow indicator is a good tool to see that the liquid is flowing, but depending on the pump you have, it can be hard to see the float move. For instance, if you have a 3gpd adjustable pump, and you run it at a low setting the float in the indicator isn't going to move very much with each pulse of the liquid.
