Thread: Timer for Stenner
    Mar 2013
    CT
    363
    Timer for Stenner
    Can anyone recommend a good indoor timer for a Stenner pump? It would be separate from my pool pump timer.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    22,703
    Re: Timer for Stenner
    Which timer are you using for the main pump?
    If you're happy with that one, I'd suggest using the same model for the injection pump. However, almost any timer will control that small pump.
    robaz's Avatar
    Aug 2015
    Glendale , Az.
    99
    https://www.amazon.com/Woods-50015-O.../dp/B006LYHG42 I use this one and find it pretty reliable...GoodLuck..
    Location: Phx,Az. IG gunite Pool constructed 1993 14x28 Playpool 3.5'/5'/4' depth.. 11,400 Gallons Finish: Acrylic Plaster (Ultra Poz) Tiled waterline Pump: 3Hp Pentair IntelifloVS Filter: Pentair TR100 Sand 4.91 Fil. area 74 GPM...Barracuda suction side cleaner........
