Thread: Pool light wattage
    Jan 2017
    Woodstock
    17
    Pool light wattage
    What wattage do most people go with for their spa light? I am getting my pool resurfaced next week and am going to change from halogen lights to the 5G LED color changing ones. I was going with the largest watt option for the main pool but I noticed there were several different wattages for the spa.
    Or am I just confused and do they come in the same wattage?
    Dec 2014
    Riverside California
    494
    Re: Pool light wattage
    The Intellibrite 5G is available in 2 sizes, a smaller one for the spa and a standard size for the pool. The 5G lights only use around 40 to 50 watts, much less than other types of lighting. The 5G spa light can be found here
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
