Results 1 to 14 of 14
Thread: Can you get too big of a salt cell?
    Feb 2017
    Parkersburg, WV
    39
    I'm in my research stage of buying a new FG pool. The pool I'm looking at is 19kgal. The PB is putting a AquaRite 25k in the bid for the pool. I see in the spec sheet that its suppose to cover 15-30k gal. Most of the post on here seem to say you should always buy the next size up SG. My question is if I raise up to the AquaRite 40k could I possible hurt any thing? Just trying to make sure it's not like a heater / AC for your house where it's never good to buy too big of a unit. You need to find the sweet spot where it's not cycling on and off all the time.
    Mike
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Can you get too big of a salt cell?
    Nope, that will work great and let you run your pump less because it will make more chlorine in the same amount of time. I have a 40k SWG and 20k pool and it works great.
    Jan 2012
    'burbs of Augusta, Georgia
    8,594
    Mike, I have one that is 3x my pool size. I rarely go above 20% on the SWG. Remember that SWGs have a certain lifespan in hours use, so the less it is used the longer it should last.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,113
    You can always turn the control down on the SWG, or just run it for less time. Just so you know, many of the ratings (in gallons) that they put on SWGs are based on running it and your pump 24 hours a day. Not exactly what you want to do.
    chiefwej
    16x36 rectangular (19k) Pebble Tec play pool/spa, Pentair Intelliflo VS 011018, Super II 2hp (spa), Aqua Rite T-15 SWG, Pro Grid 60 DE, H400 & Heliocol Solar, Dolphin S-300, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit, Smart Home/Alexa pool control
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    As others have said, its a good idea to go larger. My SWG is rated for up to 52,000 gallons for my 19,000 gallon pool. Larger means yo can run it at lower power and.or less time, and it will last longer. It also means that you can generate larger amounts of chlorine when needed - after a large party or someone has an accident. My original SWG the PB installed was rated for 20,000 and it worked for a while, but once summer fully hit, it could not keep up, even running 24/7 at 100%.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    ...and as long as you're not planning to move in the next 5 years, your total costs with the 40K cell will be better. It also matches up fine with the pump running on low or high speed.
    SWGs can be dialed down which is like having a smaller air conditioner most of the time, but a big one when it's needed or convenient.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Feb 2017
    Parkersburg, WV
    39
    Thanks guys for your help. I will be sure to make the change.
    mike
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,113
    Quote Originally Posted by needsajet View Post
    The comparison with an air conditioner is imperfect. You don't want an AC unit that is too much larger than needed. It will run in very short cycles and do a poor job of dehumidifying. But you are correct that an oversized SWG is never a problem.
    chiefwej
    needsajet's Avatar
    Jan 2016
    4,496
    Chief, great point, it was just explaining in context with OPs original air conditioner analogy, and agree it's imperfect. Although with an inverter...
    Apr 2017
    Cathedral City, CA
    326
    Quote Originally Posted by pooldv View Post
    I'm trying to finalize my equipment with the PB (hopefully tomorrow). Our pool and spa will be approximately 1000k - 1100k gallons. The PB has spec'd the IC20 and I'm asking the cost to up it to the IC40. He tells me that the IC20 is what is the correct size for my pool. I have tried to articulate that what I've read here that the large cell will have to run half as long, extending the cell life and I would guess electricity.
    My question is, if we proceed with the IC20, in the future can I simply replace the salt cell with the 40, or do need a new housing/equipment to fit the larger cell?
    POOL: 9700 gal, 9x30 attached SPA: 7x7. IG, Aqua Cool Pebble. EQUIP: Pentair Easytouch 8SC, IC40 SWG - Screenlogic (522104) w/wireless, Clean and Clear Plus 320 SF (60340), 3 HP VSP (11055) & 1.5HP Whisperflo Pumps (011773), 400K NG Heater (460736), 12 Venturi spa jets, 3 Magicstream Deck Jets II (580003), Aquastar Autofill w/anti-syphon valve, Waterway skimmer. Fill date 04/03/18. TF-100 Test Kit, SpeedStir.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,009
    Your pool size is 11000 gallons right? If so, get the IC40. Tell them that is what you want. I have a 6000 gallon pool with the IC40. Overkill, yes.
    If you get the IC20, you will be able to replace just the cell with the IC40. The power supply housed in the EasyTouch is the same for both.
    But realize, you will be running the IC20 14 hours or more a day during June, July, and August. At 100% output.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,321
    Y,
    The power supply for the IC20, IC40, and IC60 is the same, so you can just buy a larger cell later..
    That said, I'd want an IC40..
    With a Pool and Spa, IntelliFlo and IC20 or IC40, I would 'assume' that you are also getting an EasyTouch automation system.. If this is true, please make sure your PB installs a 'real' EasyTouch and not one of the cheaper 'lite' models.. They do not have a load center, have limited pump speed control, and few functions... As I like to say.. "If its 'lite'.. it just does not taste right..." Also, if you are getting the Easytouch, make sure it has the built-in SWCG power supply... you do not want the stand alone SWCG power supply..
    Here is a good example... Pentair Easy Touch Control System 520545. EasyTouch 8SC-IC40 Control System. Pentair 520545.
    Thanks for posting,
    Apr 2017
    Cathedral City, CA
    326
    Quote Originally Posted by Jimrahbe View Post
    Y,
    Thanks for posting,
    Thanks Marty and Jim,
    What the PB currently has spec'd is the Pentair Easytouch 8SC-IC20 Pool/Spa control w/ Salt, 520544 - Screenlogic iPhone/Android control, 522104 - Includes wireless connection kit ($2,823.48).
    I will be getting that changed the 520545. Though I wonder about Jim's reference to "lite". Are there EasyTouch 8SC that have a model number that would let me know it's "lite"?
    Regarding the 40 running for notably shorter times during our freakishly hot summers, I imagine that would help the electricity bill as well.
    Again ya'all are the best!
    York
    Jul 2014
    Bedford, TX
    9,321
    Y,
    Here is a link to the 520544, with the IC20... Pentair Easy Touch Control System 520544. EasyTouch 8SC-IC20 Control System. Pentair 520544.
    I too would move up to the 520545 with the IC40..
    It is not a 'lite' unit.. Lite units have an 'L' in the model number like PL4 or PSL4, etc..
    You will love SceenLogic2... it makes programming and using the ET about 10 x easier than using the little 3" LCD display on the main panel...
    Thanks for posting,
