Thread: Replace motor or pump?
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    It looks like my pool pump motor has finally died forever. I want to see if it's possible and will save money to just replace the motor with a 2 speed motor or if I am better off just replacing the entire pump.
    The 2-speed pool pump motors run for about $350.00 while the entire pump runs for about $475. I am not sure if it's worth saving the $175 and replacing just the motor.
    This is the motor in question.
    SQ1152
    https://www.amazon.com/Smith-SQ1152-.../dp/B007ATO26W
    Migoni
    20,000 Gallon in-ground PebbleTec pool, 1.5 HP Pump, Pentair Quad DE-80 filter, In-Floor Cleaning CareTaker, city water, K-2005 test kit.
    My Real Helmet assemble, paint and collect
    May 2011
    lebanon tn
    370
    Re: Replace motor or pump?
    It's pretty simple to replace just the motor. No reason to replace pump unless it's really old or if it's losing capacity or making noise
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    I forgot to give a background of what happened.
    1. Summer of 2016. Pool motor would make a humming sound and would not start. I replaced the start capacitor and pool pump worked fine until now.
    2. February 2017. Pool pump would start for about 3 seconds and then shut off.
    3. Replaced bearings and seals. No change
    4. Replaced run capacitor. No change
    5. Next steps, replace motor or pump
    I would like to use a 2-speed motor/pump, but can't decide what will be the best option.
    If I do replace the pool pump, this is the best option that I found but please let me know what you think and any suggestions on what other pool pumps would be good.
    https://www.amazon.com/Pentair-34004...Pentair+340042
    Migoni
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    I agree, replacing just the motor is pretty simple. I have already removed and installed the current motor twice.
    My question is if it's better to just replace the motor with an equivalent motor or would prefer a 2-speed motor. Knowing that the pool pump is 13 years old, it may be just better to replace the whole thing and start fresh.
    Migoni
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    There's no reason not to just change out the motor. Check out the 2EZ Speed motors, they come with built in timer and can be found for about $350. Makes converting from a single speed to 2-speed easy.
    google search: 2-speed ez - Google Search
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Thank you, this is great info.
    Also my impeller has a hairline crack on it, it may be a good idea to replace it as well.
    Migoni
