Results 1 to 7 of 7
Thread: Fertilizer from wind in pool , need to be concerned ?
    Jul 2016
    College Station
    21
    The lawn care guys fertilized my lawn last week, it was pretty windy and some fertilizer blew into pool.
    The water testing looks good, but should I be concerned and take any preemptive measures ?
    25K gal, plaster, 1.0 jandy spa pump, Two 1.5 gallon pool pumps, DE Filter, Glass Tile sheer descent and spa.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Fertilizer from wind in pool , need to be concerned ?
    Please post numbers. Also, which test kit do you use?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2016
    College Station
    21
    Quote Originally Posted by pabeader View Post
    Am using Taylor 2005. ( I know I should upgrade for better cc testing ). Water is clear and I can see a few of the smaller fertilizer granules at pool bottom, but not many.
    FC 5.0
    PH 7.6
    CC 0 ( this hard to tell, could be 0.5 )
    CA 150
    AK 110
    CYA 40
    Nov 2016
    Melbourne, FL
    139
    Fertilizer blends around me always contain Iron to green up the lawn. I would do my best to get it out if it was my pool.
    15K Gal Gunite Pool, White Pebble Surface (unkown), Pentair Intelliflo Variable Speed Pump, SunTouch automation, sta-rite plm100 filter, Hayward AquaRite AQR-15 SWG.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    If there is iron in it I agree. If not, then it will be fine. Keep your FC well above minimum, maybe just raise it to shock level for a day or two to oxidize the nutrients.
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    You don't have a chlorine test that shows FC over 5ppm. I would suggest ordering this test from TFTestkits.net and it will bring your test kit up to the equivalent of the one we recommend.
    See this --> TFTestkits.net
    They are also having a sale on refills for any other reagent you're in need of at this time.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    +1 to everything above. If it were mine, I'd brush the bottom well, a few times, to hopefully dissolve the powder you can't see. Good chance there will be no problem, but getting spots of iron stain would peave me off too much to take a chance.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
