Results 1 to 9 of 9
Thread: Mystery Material Found after spring start up
    Jun 2016
    Austin, Texas
    9
    Question Mystery Material Found after spring start up
    We are in Austin and the weather has been unseasonably warm, so I decided to warm the pool a bit a start the swim season. After doing a filter clean and testing chems (nothing was needed; all in great shape) I cranked up the run time to 12 hours a day. After a few days, this mysterious white stuff was found in the hot tub and on the tanning ledge by the bubbler. Not salt (yes I tasted it). It's flaky and doesn't dissolve. Calcium Hardness test was 220ppm. Any ideas? Should I be concerned? Thank you as always!
    30,000 gallon Salt pool w/spa, sparkle Quartz, pentair FNS Plus filter w/ Ultra UV. Pentair Mastertemp 400 heater, Intellichlor SWG, Pentair Intellifo variable speed pump, Polaris PB4-60 booster pump. Use Pentair screenlogic app. Austin, Texas
    triptyx's Avatar
    Apr 2016
    1,475
    Re: Mystery Material Found after spring start up
    Do you have a full set of test results to go along with the photo? A complete set will let us help you better.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2013
    Long Island NY
    420
    That looks like the same sediment that came out of my hot water heater when I flushed it. I thought it was calcium or lime.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    Grab some and pour a tiny bit of muriatic acid on it. If it bubbles it sounds like calcium.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    My money is on calcium scale. If it is then we can work on that. Your water is probably similar to ours in that it has high scale potential and the alkalinity can run high, especially during drought when the water sits in the lakes and soaks it up. It isn't only high CH that contributes to scale. It is the combo of CH, TA and pH. In the right mix it can easily scale with CH at 220.
    PoolMath will calculate your CSI after you enter all of your test results. Borate, salt, CYA and temp also impact the number. Keep your CSI between -0.3 and 0 to prevent scale in the pool and in your SWG cell. More here, Pool School - Calcium Scaling
    Jun 2016
    Austin, Texas
    9
    thank you for the great replies! We have been traveling so please pardon my delay in responding. Here are the stats from that day:
    75 degrees outside
    water heated to 77 degrees
    salt 3300 (not sure why it's higher than when we left it in the fall - usually sits around 2950-3000)
    output set to 50% for pool and 30% for spa on intellichlor
    FC - almost zero - again not sure why with salt at 3300
    cc - 0.2
    pH - 7.6 - I was shocked - I feel like I have to add acid every time I test (every few weeks)
    TA - 110
    CH - 220
    CYA - 80
    I have backwashed the filter twice and am still getting the mineral deposits in the spa mostly but the Polaris is picking up some too. We've kept the water warm (around 85), except for last week when we turned off the heater while we were gone. Been running for about 10 hours a day, off at night. We've had mineral deposits on this one spot for months and it was always a mystery to me as no water touches this part of the pool wall.
    An just now we noticed that the minerals seems to be leeching through the hairline cracks in the back wall of the pool
    Please tell me that this is normal? Pool is right at a year old.
    Jan 2012
    8,557
    You have efflorescence. That happens when water gets behind or into the wall and pushes the calcium or carbonate (whatever!) out and it dries on the surface. Do a search on it here and you'll find lots of threads discussing this and how to manage it. You may need to seal the walls better.
    Yip
    Jun 2016
    Austin, Texas
    9
    My CSI is -0.26 and all is showing "balanced" with nothing needed.
    Quote Originally Posted by pooldv View Post
    Jun 2016
    Austin, Texas
    9
    OK - did some searching. The first picture I posted is the wall of the spa so water would be on the other side of the wall - although I don't like the idea of it seeping through - there is finished surfaces on both sides of that wall! Should I be worried?
    The second picture is of the back wall of the pool. It doesn't have water on the other side, but does have pipes in the wall that lead to waterfalls that we never turn on. Again - should I be concerned that these are leaking inside the wall???? We did not finish our stone or the concrete wall with any type of sealer - guess that would help...
    The main solution I am reading is to add diluted MA and wash it off. But I know for a fact that MA will damage concrete and I worry about my stone and grout. Has anyone tried it on these surfaces and what dilution would you recommend?
    Quote Originally Posted by YippeeSkippy View Post
    Yip
