Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: New forum member- Thanks in advance for the help and suggestions
    Mar 2017
    Greenwood, SC
    33
    I'm so thankful to have found this website. I am a homeowner in South Carolina. I had a home built and custom pool put in in 2001. The pool is kidney shaped, about 40000 gallons with a 10 foot deep end. It has a Pebble Tec finish. it has a waterfall feature but no spa. I routinely run the pump 24 hours per day and do not close pool in the winter. Around november I quit swimming for the winter and no longer heat the pool until around March when I start thinking about raising the water temp by heater and getting the pool ready for the swim season. For the life of the pool until present I have used a Jandy cartridge filter( CL580) and a Jandy Pro Series .75 HP pump. Since the beginning I have used either a Nature2 Vision system or New Water Cycler Pool purifier for water decontamination and to, as was told to me, decrease the chlorine levels needed in the pool.
    Over the years I have become unhappy and disillusioned with the quality of the local pool company in assisting me in keeping my pool properly calibrated so i am wanting to, with this site's help, take the role over myself completely.
    I have a TF-100 test kit. My pool water temp at present is 73 degrees F. Three days ago I dumped 3 bags of chlorine "shock" in to the pool. At that time the water was very slightly cloudy but free of debris. The water initially blushed a light green then over about 48 hours became clear like it is now. I decided to test the water and here are the results:
    pH-7.5
    Cl 0
    CH 400
    TA 90
    CYA 40
    Yep, no chlorine!!
    So I'd love any insight or recommendations on what to do next with the pool chemistry. Also, any thoughts on changes to the equipment or my method of pool management would be most appreciated. Thanks
    krfuquamd
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: New forum member- Thanks in advance for the help and suggestions
    Welcome to TFP!
    That blush of green is possibly iron. Are you on a well? If it happens some more we can work on that.
    You can add your pool info to your sig so that it shows up in all your posts. More here on what to add and how to do it, Pool School - Read This BEFORE You Post
    I would be inclined to SLAM the pool just to make sure there isn't any algae lurking. Cloudy water indicates an early algae bloom.
    If you haven't changed the cartridges then you can get some new ones. I really prefer Pleatco filters. They are better, cheaper, easier to clean and stay clean longer.
    If the pump is working fine I'd keep it for now. Though, there probably isn't any need to run 24x7. More here, Pool School - Determine Pump Run Time
    Do some reading in Pool School
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
    And always keep your FC above minimum for your CYA, FC/CYA Chart
    Is that enough for now?
    Mar 2017
    Greenwood, SC
    33
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    Yes, a great starting point. I will SLAM the pool and go from there. No well, city water.
    Mar 2017
    Greenwood, SC
    33
    Quote Originally Posted by krfuquamd View Post
    Any idea how much liquid bleach to add to obtain the necessary FC level at the outset?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Pool Math up at the top of the page is a good place to start.
    Do you know how many gallons of water your pool has in it?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Here you go: http://www.troublefreepool.com/calc.html
    And fill out your signature as pooldv suggested. (Quick Links - Edit Signature)
    Welcome to TFP. Greenwood, always up to no good!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2017
    Greenwood, SC
    33
    Perfect pabeader. Thanks.
    35000 gallon inground kidney shaped pool with Pebble Tec finish built 2001
    Jandy CL580 cartridge filter; Polaris robot cleaner;
    Candy 1.5 HP Pro Series pump: Pentair IC60 SWCG
    Greenwood SC; no well; use TF-100 test kit I got online
    Mar 2017
    Greenwood, SC
    33
    9 gallons of 6% bleach!! WOW!!
    Dec 2012
    Manassas Park, VA
    212
    Most bleach is 8.25% so it should be a bit less.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    In 40,000 gallons of water 9 gallons really isn't that much.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Don't forget to buy extra. You will be testing and redosing during the Maintain portion of the SLaM
    You have removed and are discontinuing use of the Frog Water Cycler, correct?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    The reason I ask is because it is adding CYA at the same time that it adds chlorine. Your CYA level is fine now, so you don't want to add any more until after the SLaM.
    Mar 2017
    Greenwood, SC
    33
    Yes the Frog water cycler is out. It is supposed to rain heavy tomorrow. Should I wait to add this bleach and get started until after that?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Rain does very, very little to pool chemistry. Start when you are ready
    Mar 2017
    Greenwood, SC
    33
    Well just an update. Began the SLAM at 5:40pm today with addition of 5.5 gallons of 10% liquid chlorine. My CYA the day before was 40. 3 hours later(8:40pm) my FC=24.5 and CC=1. Should I check again before going to sleep or can i wait until daylight( around 6:30am ) ? Thanks.
    DFW, TX
    24,974
    In the morning is fine.
    Mar 2017
    Greenwood, SC
    33
    This am at 6:30 FC 20.5 with CC 1. Added 1/2 gallon 10% chlorine. At noon FC 17 and CC .5. Added 1 gallon chlorine. Just now( 5pm ) FC 16 and CC .5. Added another gallon chlorine. Two questions:
    1) Do I need to be checking any other pool chemistries( pH, TA, CYA, CH, etc..) during the SLAM
    2) Is the yellow pollen that is presently falling out of the sky into my pool going to impact the ability to pass the SLAM?
    Thanks all
    DFW, TX
    24,974
    No, no need to check the other things until the SLAM is complete. The pH test is not valid when FC is a over 10 ppm. No, the pollen shouldn't have much of an impact on the pool.
    Mar 2017
    Greenwood, SC
    33
    Thanks again. Just checked at 9pm. FC 19 CC.5 No chlorine added. Water looks clear to me( minus the pollen on the surface!! ). We will see what the overnight test shows!!
  20. Back To Top    #20
    Mar 2017
    Greenwood, SC
    33
    FC 17 CC .5 this am. Dang!!
