Thread: Energy Efficient upgrade available?
    Apr 2016
    Oakdale,ca
    8
    Have this pump/motor unit for my inground pool spa combo. Wondering if there is an energy efficient upgrade available? Variable speed etc. not even sure what I have... thank you! Looking to shave the PG&E bill!!!
    mas985's Avatar
    Pleasanton, CA
    11,987
    Re: Energy Efficient upgrade available?
    It depends on how much you are will to spend up front. From cheapest to most expensive options:
    1) Reduce run time. If your bill is that high, you are likely running the pump too long. You could probably reduce run time quite a bit. Currently, I am running only 2 hours per day. This costs nothing up front and will save considerably on your power costs depending on your current run time.
    2) You could replace the motor on your current pump with a two speed. Low speed saves about 75% in energy costs but it will cost you several hundred dollars.
    3) Replace the entire pump will a VS pump. Many power companies offer rebates that could lower the upfront costs (~$800) to make it competitive with a motor upgrade. Long term the VS will save the most in energy costs but usually costs the most up front.
    Mark
    Apr 2016
    Oakdale,ca
    8
    I'm open to any options and preferably one that will save me the most money... Happen to know preferable model or what's compatible or what I should be looking for? Variable speed pump sounds like best option
    mas985's Avatar
    Pleasanton, CA
    11,987
    Do you currently have have an electronic controller or a pump brand preference?
    Here a two options:
    Pentair Intelliflo VS
    Hayward EcoStar VS
    Because of the spa, I would stick with one of the larger VS pumps.
    Also, if you don't already have surge protection installed, you will need to do that as well.
    Mark
    Apr 2016
    Oakdale,ca
    8
    Ya I have aqualogic I think maybe prologic.. would the Hayward ecostar vs work? Is one better than the other?
    EcoStar should work for you. Aqua Logic, Pro Logic and Aqua Plus require main software revision 2.65 or higher.
    Go to diagnostics to see what main software revision you have.
    If you don't have at least 2.65, you can use relays to control the pump.
    The model number of your automation is printed on the inside of the door to the automation.
    Also, check for rebates from your utility.
    Support the site
