Results 1 to 8 of 8
Thread: Overflow outlet?
    Mar 2017
    Melbourne Bch/ Fl
    2
    Overflow outlet?
    Greetings. I have been an above ground pool(agp) owner for about a year now. I live in Florida and don't worry about freeze issues. I have been trying to deal with covering the pool from leaves and debris. I found a Robelle 18 foot mesh cover that I think will work great but allows water to pass through. We get tremendous rains here and wonder about the pool overflowing. I have added a 6 in wooden coping. Should I add an overflow Outlet? I was thinking about a penetration in the liner above the return but now think a hole in the skimmer near the highest point of the water level and add a hose type connect for discharge. Any thoughts?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,004
    Re: Overflow outlet?
    I am working on the same idea. I am thinking of putting a hole at the back, top of my skimmer and making a line to run the water out and away from the pool. That way I do not have to do anything. Now I have to go out and open up the valve I use for backwashing.
    Kim
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    thinking i am going to be doing the same thing. i thought about drilling a hole toward the top of the skimmer and running a 1" pvc line out.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Jul 2012
    Tallahassee, FL
    34,004
    Yep! Should be easy and fast to do!
    Kim
    Mar 2017
    Melbourne Bch/ Fl
    2
    I would think that the overflow might change the chlorine composition to some degree but I guess that's better than a cover full of water.
    chayne's Avatar
    May 2016
    419
    i will be using about 15' of 1" pvc with a screw on connector to the skimmer. run it from the skimmer to the french drain outlet in my backyard.
    Charles
    Coleman 16'x48"
    Jul 2012
    Tallahassee, FL
    34,004
    Sounds purrfect!
    Kim
    chayne's Avatar
    May 2016
    419
    fingers crossed
    Charles
    Coleman 16'x48"
