Thread: Acid wash
    Jul 2014
    Bullhead City/AZ
    9
    Acid wash
    I've had several pools, all plaster. Keep chems balanced good. I have one small section of pool that is in shade all year due to contour and orientation. This small section is in about six inches of water and at base of pool wall near step. Looks like algae, slight color of yellow/green but can not be swept or brushed away. I wonder if it is just my eyes and lighting. Anyway, thinking of acid washing this area to make sure nothing is growing. Good idea or not? I'm draining pool next month (annually). Or try chlorine wash over that area? Never have done acid wash before, suggestions? Temp gets to low 90's in summer, 50's in winter. I wouldn't think algae would survive, so does the color, if it was there during summer? I think when I drain it I will see it for what it is but your thoughts appreciated.
    Built 3/14, 12.5K, .75 HP Stealth pump (2) 1 filter 1 popup clean sys, IG plaster, Jandy DE48 filter, Paramount O3 Ozinator, Nature2 purifier, 400K nat gas heat, pool master 5-way.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Acid wash
    Could you post a test result for us?
    Also, I hope you have removed the Nature2. (It adds metals to your pool)
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Acid wash
    Here is some info on identifying the source of the stains, Pool School - Stains in Your Pool
    Jul 2014
    Bullhead City/AZ
    9
    Re: Acid wash
    Yes, did remove Nature 2. Yes I will post results.
    Thanks.
