Thread: Anyone have experience with drain-less pools?
    Dec 2016
    Austin, TX
    115
    A few builders in the area are touting the virtues of drain-less pools. Anyone have experience with them?
    Thanks.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Re: Anyone have experience with drain-less pools?
    The No Drain pools have been around for many years. I don't have a main drain in my pool and I I like it and Ive never had any circulation problems either like is sometimes claimed. I also will never have to worry about my main drain leaking.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    And there are others like me who prefer having them because of the dusty environment we live in. Wouldn't want to be without them here.
    Essential Links:
    Dec 2016
    Austin, TX
    115
    My pool is planned to have super flow 360 drains mainly because I am using some 3HP pumps for water features and want very little pump inlet drag to push water features. I might put the drain valve on an actuator and adjust inlet flow based on performance needs.
    I am leaning towards setting up the returns as you would for a drain less pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I like my bottom drain. I'll sweep debris to the drain sometimes and it is pretty convenient. It also supplies water to my pump when the skimmers are clogged with leaves. Which happens a lot with all the trees we have. But, I certainly think my pool would operate just fine without it. Especially with a good robot. I bought hp this robot last year and I do a whole lot less work in my pool now. Can't wait to see how it performs in its first spring. First Robotic Cleaner, Doheny's Discovery. Also, more about my robot in my pool thread, link in sig.
