Results 1 to 10 of 10
Thread: Pool forms types
    Dec 2016
    Austin, TX
    115
    Pool forms types
    So, I have noticed several different types of pool forms when the shell extends above grade. (On grade is pretty consistent, so I am interested in the different options for elevated forms)
    I have seen plywood used to make a straight wall. I have seen bender board used, and I have seen a steel welded wire product with fiberglass/wax paper used. There may be even more options.
    Please post up pictures and pros and cons to each so that we can learn more about each technique.
    I am deciding this weekend on a technique for a free form pool I am forming next week, so I would really like to learn more quickly.
    Thanks in advance.
    Dec 2016
    Austin, TX
    115
    Re: Pool forms types
    One more thing to add..... if the product you describe is not available at a local big box store, where would you buy it from.
    I am in AUSTIN TX for reference.
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I don't know for sure, but it seems like PBs use whatever they have handy.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    My PB used perforated Masonite. Pics in my pool thread, link in sig.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    Pegboard on ours. Pics in my pool thread, link in sig. page 1. It's just attached to the rebar used to support the wooded bond beam guide board at the top.
    Probably whatever is cheapest and available that day. It's only purpose is to stop the gunite as it is shot, not support it. Once it is stopped, it really doesn't want to slump.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2016
    Las Vegas, NV
    182
    Quote Originally Posted by pooldv View Post
    My PB used perforated Masonite. .
    [QUOTE=bmoreswim;1180552]Pegboard on ours. QUOTE]
    That's what was used on mine as well.
    Dec 2016
    Austin, TX
    115
    [QUOTE=BeachHead;1180720]
    Quote Originally Posted by bmoreswim View Post
    Did the form guy set the peg board or did the Gunnite guy place them?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    Gunite guys.
    Mar 2016
    Las Vegas, NV
    182
    [QUOTE=Ramdough;1180722]
    Quote Originally Posted by BeachHead View Post
    I suspect there will be regional differences for each trade, as building a pool involves many different steps that could be done by different people. In my case, the excavator set the "elevation" for the waterline, and created the various steps in my beam wall. This was all done with 1" x 4" board, wired to rebar stakes. Then, when the gunite crew came in, the filled in the exposed side of the walls with the peg board, using the previously set 1" x 4" as the tops. Peg board seems to be well suited to this, as it's then easy to use wire to attach it to the rebar structure. But, it would be just as easy for the rebar crew to have added this, or even the excavator crew. There's usually a "reason" for steps and materials in any process, even if it's "always been done this way".
    If your O/Bing the project, I'd talk to your subs and see what they are expecting from the preceding crews, and what work they will actually do.
    Aug 2007
    near the swamp
    806
    It's usually whatever's on the truck those days lol
    steeltex pool wire, osb, plywood, sheetrock, ect. I've seen them use sheets of metal during shotcrete down in Austrailia.
