Thread: MasterTemp 400 Not Maintaining Stable Temperature
    Sep 2008
    Melbourne, FL
    141
    A temperature issue just cropped up on my MasterTemp 400. It will heat up fine to the desired temperature ... usually 98-100 degrees; but as the spa cools down, the heater doesn't fire back up until the spa temp drops down to 94-95. Is there a way that I can keep the temperature range tighter?
    Thanks!
    Karl
    Freeform 15x31 Pool w/ oversized spa, 1 1/2 HP Blower, Pentair Quad 60 DE Filter, Heliocol solar panels, Pentair Maxitherm 400K BTU heater, Pentair IC40 SWG, Pentair Easytouch 4 w/wireless remote, Pentair IntelliFlow VSP, and Pentair Intellibrite LED Pool/Spa lights.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: MasterTemp 400 Not Maintaining Stable Temperature
    I don't know, but it sounds like a design criteria. I'm giving you a bump here in hopes that one of our members will see this, and get you an answer. There's a few who will know for sure.
    Essential Links:
    Sep 2008
    Melbourne, FL
    141
    Thanks for that Patrick ... I may just end up contacting Pentair directly to see what they have to say
    Karl
    Karl
