Thread: Help, pebble tech chipping away on floor of pool.
    Mar 2017
    Gilbert/AZ
    1
    We had our pebble tec pool emptied and refilled last week, this morning i woke up and found a half dollar sized chunk missing from the bottom of the pool. Contacted the pool company that emptied and balanced the chemicals but sounds like they may be closed on Saturday. Is this something we can patch with the pool full still or are we going to have to drain and refill again to fix the issue? Is it a coincidence that we are just now seeing this type of issue or could this been caused by the empty/refill?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Help, pebble tech chipping away on floor of pool.
    Welcome to TFP Trix!
    Sorry you didntnget an answer yet. Seems odd for that to happen, and likely may have anyway, but that's a pure guess from anyone I think. They do make putty they can patch things like this underwater with, but color matching usually isn't easy. I worry there are other places in the pool that could do this, but that's pure speculation. What did they drain and refill the pool for? Just chemical re-balance?
    Essential Links:
