Thread: We are going to purchase 33' above ground
    Mar 2017
    corinth KY
    1
    What is the best pool to purchase
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: We are going to purchase 33' above ground
    Welcome to the forum!
    It's kind of like everything else as it depends on who you ask. Hopefully you'll get some feedback to help you make the best informed decision for you. Enjoy your time here.
    Cheers!
    Essential Links:
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Too many variables to say anyone is best over another. Shop around and compare what's available to you. In general fully aluminum pools will resist corrosion and last the longest. Composite comes in second and steel last. A lot of "composite" pools have only composite top rails and lots of steel parts mixed in reducing their corrosion resistance. From what I learned in my hunt for a pool is a cheap pool often is just that. You will get what you pay for when you shop around and do your best to compare apples to apples. One final thought from reading this site is that no matter what pool you get if it's installed well and taken care of it will last you many years. Installation of the pool and it's maintenance are just as if not more important than the pool itself for how long it will last and how enjoyed it will be.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
