Thread: My pH is low - Do I use baking soda?
    Sep 2016
    Katonah NY
    172
    Hi,
    My hot tub chlorine is doing well but the pH not so high. I remember using baking soda over the summer to raise the PH. Can I do that in my hot tub or do i need soda ash?
    Rich
    JoyfulNoise's Avatar
    May 2015
    14,092
    Re: My pH is low - Do I use baking soda?
    What's your TA?
    Baking soda will do this BUT ONLY if you have the spa jets aerating the water and the process is slow. Depending on your other reading (TA, CH, etc), it may be ok to use soda ash but I would only recommend that if the pH was extremely low, as in it crashed because too much acid was added. If you're just trying to go from 7.2 to 7.6 or some small change like that, baking soda will work.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Baking soda raises TA. More here about pool chems and what they do including several to raise your pH. Pool School - Recommended Pool Chemicals
    Post a set of test results and I can offer a little better advice on managing pH.
    May 2013
    Central/East FL
    30
    Washing soda raises pH, baking soda raises TA. Unless you are below 7.2, I would just let it rise naturally.
    Screened in 15,000 gallon in-ground plaster SWG pool with attached spillover style spa. Borates 0 (might bring it up to 40-50ppm this season). Econo Flo 165 variable speed pump. Raypak 133k BTU Heat Pump. Oasis Controller. Dolphin Nautilus Plus CC Pool Cleaner. Taylor K-2006 test kit.
