Thread: Pool pump / pool return question
    Jul 2016
    jacksonville, fl
    19
    Will a 1.5 hp vs pentair pump run 3 pool returns and with 1.5" piling and run a water feature I plan to make with 1.5" piping then that one split off to have 2 water jets plus the 1.5" forward flow.
    Mar 2017
    Sunrise Florida
    19
    Re: Pool pump / pool return question
    The drain that comes from the pool is 1.5 inch as well?
    15k gallon free form in ground. Marlin blue Diamond brite finish. Gray pavers deck with gray coping. Hayward SP2303VSP MaxFlo VS pump, Hayward C4030 425 and Raypak 90k BTU Heatpump. Led pool light
    Jul 2016
    jacksonville, fl
    19
    I don't know I'll see
    It's at least that or 2"
    Mar 2017
    Sunrise Florida
    19
    Double post
    Mar 2017
    Sunrise Florida
    19
    If it's 2" you could do what I did. I made a 2 inch manifold and connected to each return pipe which were 1.5 inch. I have six returns which are really three because they are two from each 1.5 inch pipe. And I also have a small water feature which is 1". The 1.5hp pump is more than enough even with a heatpump
