Results 1 to 12 of 12
Thread: Another pebble finish question!!
    Oct 2012
    Quakertown, PA
    56
    We opened up the bidding on our pool project to another local pool builder. Actually - he used to be active on this forum. Seems to have a great local reputation.
    That being said - if we go with them, we are leaning towards their "Custom Monogram Pebble Blue" finish. I believe this is a custom Pebble finish made for them by CL Industries.
    Does anyone have experience with this finish? How about Cl Industries pebble finishes in general.
    We have 3 VERY active kids. Our pool will likely be used for basketball, volleyball, dogs, rough housing...etc. I know that any gunite pool is going to have some sort of HARD and ROUGH finish....lets face it - they are all cement based products as we are not lining the pool with feathers...but still - I wonder if Ill regret how rough a pebble finish is? I love the potential durability of a pebble finish....but have a few concerns about the "feel". If its really like an orange peel - I think its fine....
    I would love to know if this finish is smooth enough for my kids (and lets be real....also for me) to "play" in the pool without bleeding.
    Again - I do realize that if you drag your foot across any cement product (sidewalk, etc)..that its going to hurt and may bleed. But still - Im hoping the finish is smooth enough to not contribute to additional injuries.
    Also - we do plan on visiting other local pools to see and feel it in person - but I was hoping someone on here may have some input.
    Thank You!
    Sep 2016
    New tripoli, PA
    91
    Re: Another pebble finish question!!
    I'm curious who you ended up going with? I've also had a quote from them but I just signed a contract with B&B instead
    My Spring 2017 new build in PA ! //// Pool on a big hill //// IG SWG 700 sqft +100 sqft sun shelf + 50 sqft spa. //// All Jandy Pro series equipment (help me choose which models !) //// SGM River Rok or Diamond Brite (help me choose!) //// Stamped Concrete deck
    Oct 2012
    Quakertown, PA
    56
    Quote Originally Posted by A165fun View Post
    No choice yet. We didnt look at B and B. I did stop at Pelican on 309 to look at hot tubs and a few guys there were shocked that I wasnt considering B and B.
    What pushed you to B and B over M ?
    Sep 2016
    New tripoli, PA
    91
    I had a friend use B&B and it came out great. They have been around a long time and earned a good reputation. I'm thinking these are the two best in the area and you won't go wrong with either. M was several thousand more for my build
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    My plain plaster is as smooth as a baby's bottom. A standard pebble finish will be the roughest and all others in between the two.
    Have you considered Aquabright? Carlton Pools would be the AB folks in your area from what I see. It requires a basic plaster installation first for your new pool with AB on top. So the price seems to end up similar to a high end Pebble finish.
    I will consider if I need to resurface.
    The AB is a flexible material that can have a smooth or slightly textured surface, but it would have a slightly soft feel compared to any plaster finish.
    Last edited by bmoreswim; 03-03-2017 at 10:58 AM. Reason: Clarifying Aquabright feel
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    Virginia
    118
    We have pebbletec and it is very textured -- more than an orange peel, but the tiny pebbles have smooth edges. I think it would be a little rough on young kids' feet and it is possible to scrape a knee or elbow on it (if roughhousing for example). I would recommend this type of pebble over the smaller versions which can actually be more abrasive (more like sandpaper). But I also would recommend a quartz finish or plain (perhaps colored) plaster over pebble finish if smoothness is a priority. We opted for pebbletec for looks and durability, knowing a downside would be it can be a bit coarse. We love it but there definitely are smoother options available.
    IG Gunite 20x40 pool with Pebbletec finish (Tahoe blue with luminous glass in mixed jade); Pentair DE Filter and Pump; Intellibrite LED lights; RayPac 8350 Heat and Cool Heat Pump; NPT Arctic Ice glass tile; Coverstar autocover; Cambridge Renaissance Pavers in Onyx Lite; bluestone coping.
    Sep 2016
    New tripoli, PA
    91
    Which of these finishes is least likely to fade over time? I want a dark color and I've even seen people's dark pebbketec finishes fade. Is this avoidable?
    Nov 2015
    Carrollton tx
    487
    As I understand it the fade is the plaster mostly NOT the pebbles ... If you get dark pebbles they wont fade much ....Its dark plaster that people report to fade. And if you consider that the sun and chlorine are BOTH effective color bleachers .... So you should expect some fade on ANYthing that is dyed like colored plaster
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure 1400 SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Oct 2012
    Quakertown, PA
    56
    Quote Originally Posted by bmoreswim View Post
    Thanks for the reply. I know all about Aquabright (its very, very local to me geographically) and no I am not considering it at all any more.
    Mar 2016
    McKinney, TX
    176
    We don't have pebble, we went with Wet Edge Primera Stone because of the roughness factor and are happy with it. But it seems like most people are very happy with the smaller pebble/Pebblesheen types--they are the prettiest and to me they feel 'bumpy' like orange peel or basketball, but not 'rough'.
    I think kids with tender feet will always have scrapes at the beginning of swim season for a couple weeks until their feet get toughened up My son has very sensitive feet, the first few days in our pool playing volleyball for hours the bottoms of his big toes were scraped up a little--and our plaster is about the smoothest out there.
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
    Feb 2015
    Santa Cruz, CA
    409
    We also went with the Wet Edge Primera Stone finish - I am a whimp and have soft feet/skin so I wanted a smooth finish.
    If my son beaches himself on the sun shelf, Shamu style, he skin gets roughed up on his chest and stomach a bit. His feet? He hasn't complained about them since the first week when the pool was brand new...
    I haven't had any issues with the surface and love the smooth feel.
    2015 Build Link: 15'x30' Rectangle (3'-6", 5', 4' depth) 14,000 Gallon Pool, Finish: Wet Edge Primera Stone Black Kona. TF-100 Test Kit, Dolphin DX5+S Robot, Jandy CL460 Filter, VS 2HP pump, AquaPure 1400 SWG, iAqualink2, Automatic Safety Cover. No Heater
    Oct 2012
    Quakertown, PA
    56
    Quick update - I met with the PB today and was able to see and feel their custom pebble. Seemed more smooth than we expected and we loved the color. Clearly, we will touch an actual pool before we choose it, but I feel better after seeing the size of the pebbles and the finish.
    The other guys are quoting quartz so the roughness of the finish isnt as much of a concern.
