Thread: Repairing crack options?
    Feb 2016
    Los Angeles, CA
    37
    I'm not 100% sure yet that there is a crack at the bottom of my pool, but all signs are pointing that way. I had a great leak detector guy come out yesterday who checked all the plumbing, lines, lights, coping, tile, deck, and even swam around the entire pool for about 30 minutes looking for a leak with dye. He didn't find anything, but did rule out everything except a hairline crack that could have been missed from being so small. I'll be draining my pool shortly to help spot the problem, but just thinking in advance, what are my options for fixing a crack that is leaking about an inch of water a day?
    22,000 gallon in ground pool with pebble finish. Pentair DE filter with Pentair VS pump. Built in the 70s but completely redone (including new pebble finish, equipment, and plumbing) in August 2015. K-2006.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Repairing crack options?
    Our pebblesheen has cracked three times. Each time the PB mixed black and white pool putty together to get a gray (that didn't match my plaster very well ) and mooshed it into the crack. It cures underwater. One of the three cracks leaked and it hasn't leaked in 4 or 5 years.
    Feb 2016
    Los Angeles, CA
    37
    Quote Originally Posted by pooldv View Post
    Great! I'll look into that. Do you know if I'd need to open the crack wider to get down to the gunite and put putty there too or would just sealing the crack be enough?
    DFW, TX
    24,974
    He dug around in it a bit with a flathead screwdriver to remove any loose material first and that's it.
