Results 1 to 11 of 11
Thread: Expansion Joints
    Feb 2017
    Cochran GA
    29
    Expansion Joints
    Hi everyone,
    Quik question, do I have to fill in my expansion joints?
    I have no problem filling them in, just wondering if everyone else does. If it's one of those "yes, you really should do that" things.
    second, if I should fill them in, what should I use?
    I have cantilever coping around my fiberglass pool, so I do have vertical expansion joints as well as your typical ones on top of the deck.
    thanks for any help.
    eric
    IG Fiberglass 10,000 Gal; Pentair Superflow 1HP Single Speed Pump; Hayward Sand Filter(S244T); Solaxx SWG, Hayward Heat Pro Heat Pump 110,000 BTU; 12 Mil Solar Cover w/ Reel; Pool Completion Date Oct 1 2016; Top Off Using Softened And Filtered Well Water; TF-100 Test Kit And Aquachek Salt Strips.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Expansion Joints
    No, expansion joints should not be filled.
    Feb 2017
    Cochran GA
    29
    Thank you, it's spring time and I've been putting a lot of effort into the pool and just coming into these little sorts of questions that I'm on unsure of, so I really appreciate the forum, and all the help, thanks!
    Eric
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Are you talking about expansion or control joints? Expansion joints are made with a flexible material. Control joints are Saw cuts or tooled lines to force concrete to crack.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,882
    Those would be control joints. A true expansion joint completely isolates the deck from another structure or object with some sort of compressible filler (usually styrofoam). These joints do typically get filled since they are usually 1/2"-3/4" wide and would be rather unsightly without a filler.
    -Brian-
    Pool/Spa, Pentair Equipment
    DFW, TX
    24,974
    I don't think there is an expansion joint because it is a cantilever deck.
    Feb 2017
    Cochran GA
    29
    Ah, and that's why I love this forum. I didn't realize it, but I am talking about control joints, thank you for clarifying that for me.
    Eric
    If any of you have much experience with cantilever decking, could you please take a look at my other post, regarding a horizontal crack along the control joint that I'm a little concerned about.
    Hairline Crack - Cantilever Coping
    Eric
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Is that colored or stained concrete?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Fascinating! I just realized I have cantilevered coping. It looks different than a lot of others.
    Heard others discussing it but never knew what they meant. And yes it's control joints.
    Dolphin E10 Cleaning Robot.
    Feb 2017
    Cochran GA
    29
    Pyrodav,
    My concrete is stained.
    Feb 2017
    Cochran GA
    29
    Quote Originally Posted by borjis View Post
    Thats great! I really like my coping, I know there is also a round coping which is bullnose and an inclined coping where it comes out past your pool at the top then comes back in toward the pool at the bottom. There may be more, mine is flat.
    Eric
