Thread: Isolation Valves
    DonW's Avatar
    Jun 2008
    Central IL.
    96
    Isolation Valves
    In the spring it will be time to change out my 1 1/2 ball valves to isolate the pump and filter as the handles have broken leaving stubs to turn with a slip-joint pliers. The sun beating down on the equipment pad has not been kind to the valves. I maybe got 3 years out of them before the handles became brittle. My system has been hard-plumbed and I'm leaning towards a Pentair Pool Diverter Valve, super nice but less costly than Jandy valves. What has worked best for you?
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,607
    Re: Isolation Valves
    Honestly, I would just spend a bit more for jandy never lube valves.
    I cringe every time I see a new installation with those cheaper orange or blue handled valves that eventually get very difficult to turn.
    If it were me, I'd also think about building some sort of coverage for the equipment to protect it from rain and sun.
    Dolphin E10 Cleaning Robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    The Pentair valves are just as good as Jandy. I've got some of both and they both work fine and are the same after 5 years.
    Like these Pentair Valve, 3 Way Pvc, 1 1/2 Slip Od) (263037) - INYOPools.com
