Thread: how to remove skimmer with the pump running and keep debri from getting sucked in?
    Jul 2016
    Gainesville, FL
    127
    during leaf season I need to clean skimmer baskets multiple times a day and don't want to shut off the pump every time. Is there a way to "lock" the weir in upright position to block the flow while you are cleaning the skimmer?
    Inground 28000 gal Concrete, Hayward Progrid DE filter 6020, US motors 1.5hp pump (3450rpm) , Polaris 360
    600 gal hot tub, Spa Vita, Nature2+MPS
    Re: how to remove skimmer with the pump running and keep debri from getting sucked in
    If you lock the weir with the pump still running it'll block the water to the extent that the pump will (likely quickly) empty the skimmer, and then the plumbing...and then the pump will start sucking air and will lose prime.
    Mark
    -- Courtice, Ontario, Canada. "Cabo San Backyardo"
    12x16 3/4 inground - Hayward 3400VSP, Sand Filter, Rooftop 4x20 solar w/ Hayward GL235 automation.
    Previously installed at a neighbors, before, during & after photos HERE!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    just reach in and yank out the debris....the suction should keep the basket from coming out.
    you won't get it all, but likely most of it.
    Dolphin E10 Cleaning Robot.
