Thread: Acid Washing Pool - Questions
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    14
    I have stains in my white pool plaster. I have tried scrubbing this out to no avail.
    Pool is 6 years old and I was think I would acid wash to help remove stains. I did an initial acid was around top perimeter and it did clean up well.
    I read a number of posts that really seemed to discourage acid washes - reducing life of plaster, etc. I was planning to make sure to use as light a mixture of MA as possible to minimize the impact.
    Should I do a no drain acid wash instead - will need to research this further. Pool being pumped now!
    Appreciate the experts guidance on this please help! Thanks in advance
    Pics attached
    23,000 IG plaster pool, Jandy HP Plus 2HP (130 GPM), Jandy CV460 Cartridge filter, Polaris 280, Jandy LXi 400,000 BTU Heater, Jandy Watercolors LED lighting, 7' Raised SPA
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Acid Washing Pool - Questions
    Have you read this article? Pool School - Stains in Your Pool
    First thing to do is determine what the stain is.
    If it is organic then elevated chlorine and brushing will remove it.
    If it is iron or copper then acid will remove it.
    If you do need an acid treatment to remove the stain then this is the order to try them, from least aggressive to most aggressive.
    First, AA treatment
    Ascorbic Treatment to rid Pool of metal stains
    Second, no drain acid bath
    The Zero Alkalinity Acid Treatment
    Third, drain and acid wash
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    14
    Thanks for the information this is very helpful.
    I read through this material. It does appear to be organic as I scrubbed with Clorox chlorine crystals and that did remove some of the stain. For organic stains I see that I need to maintain the pool at 60% of the shock chlorine level. For how long - until I am satisfied or tired of scrubbing daily lol?
    DFW, TX
    24,974
    LOL! Yep, that'll do it. You can go up to full shock level, it won't hurt and might help, if you want to. How long? It depends. Really hard to say how long, depends on lots of factors. I would guess a week or two.
