Hi all,
I'm considering two options for a replacement pump this year.
I've currently got a 1HP Hayward Superpump, currently with no timer setup, just a simple on/off switch.
Option 1 - Pentair WhisperFlo 1/2 HP single speed
Option 2 - Hayward Superpump II - 2 speed (1.5HP / 0.25HP)
General questions.
I'm wondering if the WhisperFlow will have enough flow to keep the heater going.
For the water slide - with the SuperPump, I'm OK if the slide only works on the high speed setting, however It would need to also work with the WhisperFlow.
I'm wondering if the 2 speed may be more complicated then necessary for my setup.
Appreciate your thoughts and feedback - Thanks!
Some answers to the common questions I've seen asked here.
What is the pump elevation relative to the water level?
General questions.
Pump is about 3 feet below water level
Do you have any water features, spa jets, floor cleaners, suction/pressure cleaner?I have a slide that has a water output at the top. About 7 feet above the water level. It is controlled with a valve at the slide.
What is the diameter of your suction and return lines and how many do you have going from pool to pump?No main drain, One skimmer, Two return jets - All are 1.5"
What is the distance of your plumbing runs pool to pump? Approximately 50 feet from the skimmer and one return on the far side, the other return is on the close side.
What is your current pump voltage setup?240V
